relocation brackets or hose mod?
Old Apr 18, 2006 | 10:35 PM
02SOMWS6's Avatar
Default relocation brackets or hose mod?
I need to lower my rear stance a little bit to get some more clearance around my tire and the rear quarter. I just switched to a 28" tire. I would 60ft. good before(1.62-1.56) with a 26" tire. I just switch to a bigger tire,full spool and 4.30 gears. I hooked great with out the relocation brackets, will I hook better with the brackets? Then I read about doing the hose mod and pulling the upper spring cup rubber. The hose mod should get me a 1/2 inch so for now I'm going to try that.
Old Apr 19, 2006 | 12:12 PM
camaroextra's Avatar
relocation brackets always help, even if your car isnt lowered
Old Apr 19, 2006 | 12:33 PM
Honda Hunter's Avatar
How? I was always told theyre only good if you need'em.
Old Apr 19, 2006 | 12:55 PM
jimmyblue's Avatar
Moderator
They always change the link angle in the direction
that favors bite. More than you need to not spin, is
just no benefit -now-. But next mod, you might be
on the other side of it, so what the hell, do it. Used
bolt-ins are a can't-go-wrong proposition.
Unless you hook so well you break something between
tires and motor....
Old Apr 19, 2006 | 01:04 PM
That's pretty much why I did it.
Old Apr 19, 2006 | 08:01 PM
jimbo98z's Avatar
I'm confused though. Why would you lower the car if you're putting bigger tires and trying to gain clearance? Maybe I'm missing something...
Old Apr 19, 2006 | 08:21 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
just b/c you want bad *** traction, doesn't mean you don't want your car to look good.
Old Apr 19, 2006 | 09:06 PM
02SOMWS6's Avatar
the tighest spot is in the front and back of the tire, not the top. The way my car sites is a little high in the ***. If I drop the rear 1 inch it would be factory height or higher because of how my adj. torque rail is.
Old Apr 19, 2006 | 09:47 PM
This is on your new tires right? have you rolled your fenders?
Old Apr 19, 2006 | 10:09 PM
02SOMWS6's Avatar
No, I havent yet, my buddy does body work and paint so I'm gonna have him take a look to see what he can do.My problem is at the bottom of the wheel well opening. I drove onto my car trailer and strapped down the rear to see if it would hit and it was fine.
