Driverside Strut removal question
Old Apr 24, 2006 | 07:43 PM
SLPSS99's Avatar
Default Driverside Strut removal question
Ok I have been following the instructions on LS1howto.com and got to the point of taking the bolts off the Master Cylinder and do not see how I am going to get the one torxs bolt out? I can just get the 50 torx socket on there but no room for a socket wrench. Any Ideas what I am doing wrong?
Dan
Old Apr 24, 2006 | 07:51 PM
BackinBlack02SS's Avatar
Dan
You need to pull the master cylinder completely out of the way.
Old Apr 24, 2006 | 07:54 PM
Krab's Avatar
No, you don't have to pull the master cylinder completely. All you have to do is wiggle the reservoir over to the passenger's side a little. It won't move much, but it should give you just enough clearance to get a thin ratchet in there (with the torx socket). You could also try an allen wrench with a long bar on it so you can have a little more leverage in case your ratchet is too fat to fit in that tight space. It's a pain in the *** to get that bolt off, but it is possible.
Old Apr 24, 2006 | 07:57 PM
There is no way you are going to get a torx bit with a ratchet on there unless you move the maste cylinder out of the way completely. Even if you could, why would you make it harder on yourself when all you have to do is pull back a little bit and slide it over, takes 5 seconds, and gets it the **** out of the way.
Old Apr 24, 2006 | 07:58 PM
Dustin's Avatar
I pull the master cylinder off of the studs and move it to the passenger side giving me enough room to turn a socket wrench.
Old Apr 24, 2006 | 08:21 PM
SLPSS99's Avatar
Thanks for the replies, I ended up just pulling the Master Cylinder off and it was a breeze
Dan
Old Apr 25, 2006 | 11:43 AM
J. Brown's Avatar
You can fit the torx socket on and use a wrench on the socket shank.
Old Apr 25, 2006 | 11:50 AM
keliente's Avatar
When you go to reassemble, put the torx bolts on the passenger side strut tower, and then the regular bolts on the drivers side...next time you won't have to remove the master cylinder (I am always afraid of bending/breaking the lines).
Old Apr 25, 2006 | 02:23 PM
Krab's Avatar
Then I guess I did the impossible...
Glad to hear you got it out SLPSS99.
Old Apr 25, 2006 | 02:40 PM
J. Brown's Avatar
me too.........I only needed to loosen the master cylinder...........
