Eibach sportline questions.
Eibach Sportlines are intended to make the car handle better correct? I purchased a 2000 z28 with them on the car recently and it seems to handle great but then again my other car is an old explorer so anything handles great compared to it and i haven't had an f-body in a year or so. If it is to make the car handle better then why are they suposedly softer then stock? Also if i run a tsp true dual setup will i encounter problems? I'm running c5 vette rims and tires so it isn't all that low. Will the sportlines help or hurt me at the drag strip?
they are definitely a softer spring and practiacally the lowest you can find. due to them being low it does help handling due to a lower center of gravity point but on the other hand they don't exactly ride all that great as the spring rate is extremely low. true duals may or may not be a problem based on how far they are tucked up underneath. also for the strip... sportlines will hurt traction out of the hole. i recommend investing in some new shocks which will improve the ride A LOT more. also some LCA's and RLB's too! but you gotta admit the stance and the way it sits is sweet
Yes it is nice. I was told it has strano shocks on it or something. And yeah i noticed it hooks like crap outta the hole but once i get it rolling it hooks pretty decent for street tires. How do i know if it has sportlines or pro's on it? It does sit all that low in my opinion. I can still get a regular floor jack under it and everything. I owned a few stock height f-bodys that i actually had more trouble jacking up.
Sportlines - red colored springs
...should also say on both of the springs the name of what it is
They are softer than stock because they are mostly an appearance spring. Lowering the car generally will help handling, but sportlines are too low (and soft) for proper suspension travel (without many other mods that involve shortening shocks and cutting on the car, and then they are too soft).
IMO the only reason to have Sportlines is if you want to look like you have Sportlines...
LS1Tech Sponsor
so for sure ALL sportline springs are red and prokits are black? All of them? I was aware from my previous owner i had sportlines but my springs are black, any way i can find out for sure without digging into ****?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
yea same, just curious, previous owner told me eibachs, 2" drop but it may be the prokit. I still love the stance but curious as to what i actually have now
__________________
Your right on the height
Originally Posted by ChoiceCam00
What do you mean they are softer, they might be soft with stock "Canadian" struts and shocks but not with performance parts. I have the KYB AGXs, front and back set to 4 and the ride is perfect. I had them set to race 8 and stiff like you wouldn't believe! On the height, you are right, I had a 2.5+ drop front and back. Check out my white SS at http://s11.photobucket.com/albums/a197/choicecam00/ Have fun, later, Kevin.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Headers
Originally Posted by NHRAMAN
What do you mean " Canadian " is that a JAB.?? ...also shocks have NOTHING to do with height...... ...BTW...is that a 2.5 " drop in those pics???? I guess you do not have headers huh.
Does anyone know what the ride height is from the highest point on the wheel well? Reason i ask is that my car is lowered with what appears to be sportlines but it goes up my driveway with the same amount of issue (barely any) as my old stock height 93 z28 did and the jack fits under it just as easily.
