Strano vs Eibach
Old May 1, 2006 | 09:47 AM
ProjectCamaro's Avatar
Default Strano vs Eibach
Are the Strano bars really that much better over the Eibach one's. I mean Eibach is known for it's suspension products, are the Strano's really worth the extra $100?
I'd love input from people who have aftermarket sway bars and not just from what you've heard. I've searched through all the old posts already.
Old May 1, 2006 | 10:20 AM
jimmyblue's Avatar
Moderator
I didn't know Eibach made sway bars for the late F-body.
Have yet to see anyone comment on them or even
mention, 'til now.
I've found my Strano bars to be nicely balanced and a
marked improvement over stock. Balance F/R is something
that makes for predictable (in a good way) handling in
aggressive driving. You can find some bigger bars out
there, but as a rule they are solid (heavier) and you do
not want any more nose weight than necessary.
Old May 1, 2006 | 10:57 AM
Sam Strano's Avatar
LS1TECH Sponsor
This is they same Eibach that changed their bars sizes after years of 32/21 to 35/25..... They didn't get it right the first time, and worse they didn't get it right the second time. And FWIW, ST and Hotchkis (both of which I sell) are the same or similiar sizes and have been forever. *IF* the car worked well with a 35/25 type combination on it, I would have never done my own bars..... I wouldn't have had to.
My bars aren't the fanciest. They are the sizes I wanted based on my autoxing, they are hollow so you don't drag around 20 more pounds than you need to. They are function over form, which I readily admit.
The bitterness of a poor quality (or in this case just the wrong application) remains long after the sweetness of a cheap price is forgotten.
In short, cheaper isn't better. I understand wanting to save some bucks, but you usually get what you pay for.
__________________
Old May 1, 2006 | 11:06 AM
trackbird's Avatar
I have one of Sam's rear bars on my car and it's been excellent. I had the Suspension Techniques 35/25 combo and it was just too much rear bar. I switched to the 22mm hollow bar from Sam and (with my setup and driving style) it was just right.
I had one of Sam's hollow front bars and I can tell you that it is far lighter than my 35mm solid. I never got it installed on my car because of a cross threaded bolt on my current bar. I decided to keep the 35mm ST bar instead of risking breaking off that bolt (or it would be on my car now as well). It was lightweight (really light) and well made.
Old May 1, 2006 | 01:11 PM
Foxxtron's Avatar
From my personal experience, I didn't like the fact that I too once had a solid 35mm front/25mm rear, and even with stock springs, handling was a b****. Talk about less predictable limits to detect. When switching over to stranoparts/addco bars, I literally discovered what I was really missing. I also appreciated the fact that the both bars were hollow. I was going to retain both 35mm/25mm bars from the other set (brand name unmentioned), but then decided to sell them off, not to another f-body member, but...
to a metal scrap shop. Didn't like to admit that, but it was better that I did something like that rather than just dump it to end up in a landfill, or even be disingenuous by selling to an unassuming F-body owner.
FWIW, Sam did do his homework with concern to sway control and has an outstanding company that manufactures his bars.
Old May 1, 2006 | 01:56 PM
Honda Hunter's Avatar
How would these bars do on the dragstrip?
Old May 1, 2006 | 02:02 PM
Sam Strano's Avatar
LS1TECH Sponsor
Drag racing and handling are diametrically opposed. One you want tons of weight transfer and a loose suspension, one you don't. I build suspensions to handle, not to drag race (because any idiot can do that...).
Do folks run at the strip with my bars? Sure, but that's not the intent of them. ANY front bar hurts weight transfer. ANY larger than stock rear bar will help get you a more square launch.....
__________________
Old May 1, 2006 | 03:21 PM
Predator's Avatar
You'd be a very happy camper with Sam's sway bar(s).
Old May 1, 2006 | 03:52 PM
Viper's Avatar
FWIW, even with Sam's 35/21 combo I did no worse at the strip than stock. I have no intention on launching at 5K or anything, but again, 2.1 60' on a 6-speed is about normal with 3:42 gears and Nittos.
Old May 1, 2006 | 05:20 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Forget Eibach. Get the Strano bars and be done with it.
