My Koni's are complete
Got my rear Koni SA's on Friday...car feels great!
Props to Sam for the Koni's and to the girlfriend for getting them for our anniversary!
Rides perfect, car feels very stable, Mike (churp0ka or however you spell his damn name) said that you only feel bumps once, and I have to agree. It's a completely different animal now. I'm very pleased!
Originally Posted by chupr0kabra
Cool! Glad you like them. What are your settings?
-Mike
-Mike
I'm running about half (4 sweeps from full firm) on the front and 1.5 turns from full soft in the back. I'm experimenting more with the back shocks. I started them at half a turn from full soft when I first got them, but the back felt a little floaty, so I tightened them to a full turn and ran that way for a while. Now that I'm daily driving it again (totaled my Escort), I'm running them at 1.5 turns because I keep bottoming out over large bumps (mini hills) and the driveway at work has a couple small speed bumps that also cause me to bottom out. The curse of 315's. I just set them to 1.5 turns yesterday and drove it a little, so it's too early to tell if I'll like them that way. I prefer the ride a little firmer, especially after running the KYB GasAJusts for so long, which were WAY too soft.
It's nice to have the flexibility, though, isn't it?
What are you running on your fronts? What sway bar, too?
-Mike
-Mike
I'm running 1 sweep towards the firm side on the fronts and have stock sway bars.
LS1TECH Sponsor
First off, let me thank you all for your business.
Second, it always makes my day to see such happy folks.
Third, and this if more for the group at large..... Notice the differences in shock settings these guys are running. As you can see they all like what they have, which is why when folks call me, I kind of need more information than "I want it to handle well". Any word, be it handling, ride, etc, can have (and do have) VERY different definitions depending on who you are talking to. That's why I pry and poke trying to figure out what you don't like about the car before I can recommend anything to you.
J. Brown, don't rule out trying some more damping, primarily in front, just to see what happens. I think you'd like a bit more.
OneMeanZ. Glad the shocks got there for you. I wish Koni would just bring in a ton and quit running us out of them bi-annually. And you just wait until I can get you on some swaybars.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Two of them are stock, one has Hotchkis.
__________________
I bought the Koni's/ Hotchkis springs for my SS from Sam a year or two ago and I also love them! I don't get as much time as I'd like to mess with the settings either, but it is fun to do occasionally. I run mine about midway in the front and about one turn from full soft in the rear. So far, that seems to be working pretty good for me on my DD. I also added a set of subframe connectors not long after that, which also helped a lot! Oh, and I am also running stock sway bars. Congratulations on the purchase OneMeanZ!!
Stock......lower spring perch. Sam what will the front feel like with a little more damping? it's not going to be jarring is it? What should I expect?
LS1TECH Sponsor
Originally Posted by Dom
So Hotchkis springs are recommended with Konis if one wants a little stiffer spring and lower a bit? That's exactly what I'm looking for. My car is just a daily.
What are the spring rates on the Hotchkis and how much of a drop?
Parts are recommended for a variety of reasons. And FWIW, many folks think they need "stiffer springs" because their shocks are so bad, not because they really need stiffer springs. And you can lower it a bit with Koni's and stock springs too.
In short, there is no way in hell I'll tell you that the Hotchkis are "recommended" for you. I did recommend them to these guys, but then again I also recommended stock springs to a few them too. And sometimes I use LS1 Pro-kits. Sometimes I use LT1 Pro-kits. What I recommend varies because no two situations are alike.
__________________
LS1TECH Sponsor
__________________
Originally Posted by Sam Strano
Just try it and see. I'd rather you give it whirl than just assume. And I don't want to plany a seed in your head. It'll feel more damped. More controlled. If you don't like it back it off some. You have adjustment, use it and see if you find something you like better. If you don't, just go back.
Ditto what Sam said on this one. I was a little skeptical about going to 1.5 turns on the back shocks and the jury is still out, but so far, I really like it. From my experience, with my setup, my driving style, my roads, my butt-o-meter, the ride isn't jarring so much as you just feel smaller and smaller bumps in the road.
For example, there is a road near my house that has grooved pavement. On half soft front/One turn from soft rear, I could barely feel the grooves. After going to 1.5 turns from soft on the rear, I am now more aware of the grooves.
The bottom line is, you spent the money on the shocks, so don't be afraid to play with them.
-Mike
Please stop. You can't pick parts (and I can't recommend parts) based on internet chatter.
The reason I want stiffer springs is because of my 96 camaro. I put 1LE shocks/springs/sway bars, LG LCAs and I loved it. I wasn't basing my needs on internet chatter, just personal experiences. The car handled great. I was looking at ls1 pro-kit first since it has #400 front springs. 1LEs are #360 and that was right about where I liked it for my needs. So #400 should be good for my needs also. I don't think I want more spring rate. I saw the Hotchkis mentioned and I was curious about their rates and drop. My 96 V6 is lower even after it got raised a little bit by 1LE springs then my 00 Z28. I don't know why it sits so abnormally high. I just bought it 2 months ago with 73K miles and it looks like it has stock shocks/springs. It also handles horribly compared to the V6. Yes it needs shocks very bad, and it will get Konis. All it has is KBDD SFC and KB STB.
LS1TECH Sponsor
But you see the point is you don't know it's the spring rate. And I contest that it's not. 1LE shocks (either the 96 and later Koni's, or the pre-96 Decarbon's) are much better than the normal shocks you have now.
I ordered a Z28 to autocross, and picked it over a 1LE. More non-1LE's have won F-stock championships than have 1LE package cars. It shows the stock springs are really a problem. Might want to change them, might have reason to. Then again, might not.
__________________
I think I'm going to go mess with the adjustments now. What would you recommend to use to adjust the front shocks, I've tried an alan wrench before but the damn thing felt like it was going to break.
And I always enjoy doing business with Sam
