Strano Performance Lowering Springs
#121
Got mine today!!!! I will get them on, hopefully this weekend (playing in a tennis tournament, so it can be all weekend or just one match, who knows, plus starter went bad on Fiero, so I have to fix that). Will definitely get them on by next weekend for track day. I have never done this so hopefully it won't be too hard. There are good instructions on LS1install.
#123
If you put your shocks on, the springs are exactly the same in the front...... Less work in the rear.
Remember you'll need to align your cars!!!!!
__________________
#125
The springs should settle little, if any. And for those of you on stock springs, the alignment will be way, WAY off. So get it done ASAP.
__________________
#128
Originally Posted by MiaSSmaro98
sam will they be any good on a convertible
Originally Posted by Sam Strano
Convertibles.... these will work on them, but they are firm and designed first and foremost for handling over ride. The spring rates are not outlandish, the fronts are similar to (but not the same as) a number of springs out there now. The rears are actually softer than a number of springs, but 25% stiffer than stock rears. Up to you for a convertible. We've done springs on them without issue before, but we don't use ballistically stiff spring anyway, and always use good dampers, which is a huge key.
#130
Originally Posted by Ojustracing
Oh, Sam Nice Color choice. They look good though.
John
John
Jon
#136
A reminder for you folks. I need data. Including what the ride height is now, and what springs you are on to get that ride height. And I need you to measure the car with my springs after a bit of driving.
All information comes back to me directly, and is NOT for public consumption at this point. You are beta testers, basically, and the information has to be reviewed first.
Jon
#139
They are white. I wanted a color that not eveyone else uses to the springs are easily recognized if the writing comes off.
__________________
#140
soo got my springs yesterday and my koni sa's today only one problem... wasnt I supposed to get a sam in the box to help me install ![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
imma see about getting some floor time at the auto-hobby shop on saturday to get all the measurements and put these on...
