Does cutting springs increase spring rate
I have heard that cutting springs increases the spring rate. Any truth to this? I have coil overs on all 4 corners, and once the car is actually together and driveable, I want to be able to "tune" my suspension. I have a few sets of springs that are the correct length for my setup...all having different spring rates. But I have some springs, from different applications. They are semi-weak spring rates, but are considerably longer than needed. If I cut them to length, will the spring rate increase? If so, by how much?
Yes, the spring rate increases. Think what would happen if you took your spring and unwound it to where it was a straight bar. If you lengthened it, it would be easier to twist. If you shortened it, it would be harder to twist. Same principle as the old Chrysler torsion bar suspensions.
Good point...I should have thought of that. But how much (per coil cut off) will it increase? Is there a known standard, or does it depend on the particular coil?
Id Guess Devide The Spring Rate By The Number Of Colils On The Spring As A Estimate?
But That Just A Wild Guess
Actaully I Would Say Jus Tthe Oppsite Though I Mean Wouldent Less Coils Mean Less Material To Hold Up The Car?
But **** If I Really Know
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Found this on a motorcycle website: "A spring’s tension rate, in inch lbs per inch, is inversely proportional to the number of coils being used. The fewer the coils the stiffer the spring rate. One way to think of this is it’s easier to bend a piece of rebar that’s 6ft long versus’ one 2ft long. Now you understand why when your 18yr old neighbor kid cut his springs to drop his car lower the car now bounces down the highway. The spring rate has been increased due to less coils but the damping rate remained the same. The springs are now overpowering the damping circuits"
k = d^4 G / (8 D^3 N)
where:
d = diameter of the wire
G = Bulk Modulus (material property)
D = Diameter of the spring
N = Number of turns
k = spring rate
