Best compromise between dusting and effectiveness
Also, what's the correct bedding process? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Will be putting on AutoZone rotors at the same time.
<strong>Another vote for raybesto's ceramic's . Best of both worlds little dust, less rotor wear = metallic's use ferrous metal in pads ceramics use non-ferrous metals. Raybesto's is everywhere + they make pads for car quest that are the same parts.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll tell ya what, carquest pads suck. I put an end to them by melting them from a hard brake from 145 to 70. Never again will get them.
<strong>Did you buy the ceramic's ? They probably have 3 different grade pads for a f-body. + if your beatin' the sh#! out of your car at those speeds don't go ceramic use metallic's or better yet upgrade your entire brake system.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't know for sure, all it said on the box about the type of pads was semi metallic organic pads.
