How to disable ABS?
Will pulling the fuse(s) do the trick? I need this for road racing and such.
Dope
I unplugged it into the pumpkin a few years ago and it no longer worked out back, and I don't think the fronts worked either.
Glenn: hopefully I won't find out. You don't want ABS on an actual track. If you were to ever spin out you need to lock the brakes in a spin to prevent from arcing. When you lock the brakes the car will spin in the direction of your momentum, which means you are less likely to hit things and people are less likely to hit you (predictable skidding). With ABS the brakes will be locking/unlocking which can lead to unpredictable effects when the car starts grabbing.
Ask anyone who does actual track events (not dragstrip).
Dope
Hey I'm a Bill S too ! Bill Springer to be exact, and I fully concur with what your saying. I currently just do lapping days, racing schools, and the occasional Silver State Classic <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> but, I must say that if you disable the ABS, then your automatically a slower driver. Don't prep your car to handle a wreck well, prep it to race well and that involves using your ABS to it's fullest. If you don't, then plan on being outbraked at the end of every straight by guys who DO use their ABS. The choice is purely yours .
Good luck out there!
Dope
