Rotors
Old Nov 12, 2002 | 09:17 AM
ZippyZ28's Avatar
Default Rotors
I need good cheap rotors, to remedy my warpage problem...thanks
Old Nov 12, 2002 | 10:24 AM
Z-Rated's Avatar
Default Re: Rotors
I heard that the autozone rotors are good, i think i might get them next.
Drew
Old Nov 13, 2002 | 12:31 AM
unit213's Avatar
Administrator
Default Re: Rotors
Here we go again...
Save yourself some $$$ and get the Autozone rotors.
Old Nov 14, 2002 | 09:00 AM
Vic@FishersAutomotive's Avatar
Default Re: Rotors
DO NOT BUY AUTOZONE !! Either get you a good set of aftermarket rotors are OEM. If your have a consistant problem with warpage you need to diagnose the problem. Are you torqueing the lug nuts?? What type of pad are you running (Pads can build up to much heat and cause the same problem) You may have a problem in the rear brakes. Sometime if you rear brakes are not working properly your fronts are doing to much and causing the front rotors to overheat. Stop for a few minutes and look at the BIG picture and not the most obvious.
Old Nov 14, 2002 | 10:44 AM
unit213's Avatar
Administrator
Default Re: Rotors
Why do you discourage the Autozone rotors Vic?
I think they work great. IMO, they are just as good as OEM rotors if not better.
Old Nov 14, 2002 | 11:01 AM
unit213's Avatar
Administrator
Default Re: Rotors
BTW, check some of these out...
https://ls1tech.com/ubb/cgi-bin/ulti...;f=25;t=000437
https://ls1tech.com/ubb/cgi-bin/ulti...;f=25;t=000626
https://ls1tech.com/ubb/cgi-bin/ulti...;f=25;t=001268
https://ls1tech.com/ubb/cgi-bin/ulti...;f=25;t=001103
There's a few opinions on them. Some good, some bad. I hope that helps.
Be sure to torque your lug nuts too 100ft/lbs to prevent warping.
Old Nov 14, 2002 | 11:10 AM
mitchntx's Avatar
Default Re: Rotors
I'm SOLD on AIMCO rotors from Autozone.
I use them (abuse them, actually) with Hawk Blue and Panther Plus pads at a local road course, turning times a few seconds behind a ZO6 and pulling away from M3s and 911s.
I can typically outbrake an M3 and sometimes a 911, depending on the driver's *******.
And at $35 each, it doesn't break the bank.
So, for daily driving, they would be just fine.
FYI ... I torque my lugs to 85lbs. 100lbs in the heat I generate will almost weld the lug in place.
Old Nov 14, 2002 | 02:49 PM
ZippyZ28's Avatar
Default Re: Rotors
I always torque my lugs, I'm not stupid, and I bought the autozone rotors put em on the other night and they are working great so far. I am pretty good with brakes too, My 95Z had 95k miles on the original rotors never even turned. I say the stockers just SUCK!
Old Nov 14, 2002 | 03:39 PM
02SilverWS6's Avatar
Default Re: Rotors
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mitchntx:
<strong>I'm SOLD on AIMCO rotors from Autozone.
FYI ... I torque my lugs to 85lbs. 100lbs in the heat I generate will almost weld the lug in place.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What mods do you have? If you were a few ticks behind a Z06 then you must have some mods! Let us know!
Old Nov 14, 2002 | 03:43 PM
unit213's Avatar
Administrator
Default Re: Rotors
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ZippyZ28:
<strong>I always torque my lugs, I'm not stupid, and I bought the autozone rotors put em on the other night and they are working great so far. I am pretty good with brakes too, My 95Z had 95k miles on the original rotors never even turned. I say the stockers just SUCK!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Damn dude, no one said you were stupid. We are trying to help you out here.
Old Nov 14, 2002 | 04:04 PM
ZippyZ28's Avatar
Default Re: Rotors
I'm not saying you are saying I'm stupid, I am just saying if you don't torque your lugs you must be stupid. By the way the guys that recommended the autozone rotors RULE! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Nov 14, 2002 | 04:30 PM
Bad Blu Formula's Avatar
Default Re: Rotors
You might want to check out the Rototech rotors. My dad kjust got some and they're pretty nice.
Old Nov 14, 2002 | 06:17 PM
00NBMCamaro's Avatar
Default Re: Rotors
autozone didnt have rotors for me so i got NAPA rotors..very nice quality but made in canada <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> i also got the NAPA brand ceramic pads(made by ceramix) and they have been bad *** thus far..almost NO brake dust and stop distance is way better
Jeff W <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Nov 14, 2002 | 07:15 PM
Default Re: Rotors
For you guys that are runnng the Auto Zone rotors and having good luck more power to you. Maybe in the past few years they have made improvements in some of there product lines. If there working and cheaper then keep using them. As a shop though I do not use anything from there because it is a common kwowledge that a lot of there parts go bad. I have had people tell me (quoted-they have a lifetime warranty and all four times it failed they warranted the part). For my shop we do not want a part thats going to fail. My suggestion on torque is common question (most people do not know what it is). As Camaro LS1 <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> said only trying to be helpful (No Offense).
Old Nov 14, 2002 | 07:34 PM
mitchntx's Avatar
Default Re: Rotors
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 02SilverWS6:
What mods do you have? If you were a few ticks behind a Z06 then you must have some mods! Let us know!</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">www.motorsportranch.com
This place is not so much about horsepower as it is handling, brakes and ******* ...
Mods ...
G2 everything ... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I run 1:28s and 29s ... a ZO6 will run 1:24s and 25s
G2 LS1 has a Camaro that will hang with and outrun ZO6s. I've learned a LOT from him and his dad ...
<small>[ November 14, 2002, 07:35 PM: Message edited by: mitchntx ]</small>
Old Nov 15, 2002 | 08:03 AM
unit213's Avatar
Administrator
Default Re: Rotors
Vic@FishersAutomotive,
No offense taken. I was interested in hearing your objective opinion.
ZippyZ28,
I'm glad the autozone rotors worked out for you!
