NITTO dr`s
<strong>yes. nittos are like stock tires but alot softer so they grab the road better,if you heat them they grab even better.you can drive in the rain with them too.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is not correct. The sidewalls on Nitto drag radials are soft. You have to be careful taking turns at a high rate of speed because the tires will have a tendancy to "lay over".
You have to be careful taking turns at a high rate of speed because the tires will have a tendancy to "lay over".[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Does this mean the Nitto's will not take corners as good as my factory F1's?
BFG's have the same sidewall effect?
<strong>"Does this mean the Nitto's will not take corners as good as my factory F1's?"
I think they'll handle better.
Funny problem I have now with DRs in the back and regular Nitto radials up front is that when taking hairpin turns the fronts start to push before the back tires will slide. Think I might go with DRs all the way around next time.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think I'm gonna try BFG drags all around. Which ones should I get?
Will they hook better ON THE STREET ONLY than Nittos?
On the street the Nittos will easily outhandle and outlast the BFGs. They work well in the rain. BFGs don't. They also look much better, IMO.
