Are LCA Reloc. Brackets hard to install?
Old Dec 20, 2002 | 12:53 AM
99Z28RS's Avatar
Default Are LCA Reloc. Brackets hard to install?
I have the Eibach pro-kit and i was wondering how hard it would be to do the LCA reloc, and then i know a panhard is easy. thanks
Old Dec 20, 2002 | 03:46 AM
SSactionLs1's Avatar
Default Re: Are LCA Reloc. Brackets hard to install?
easy...took me 1hr to do LCA, brackets, and Panhard
Old Dec 20, 2002 | 10:29 AM
99Z28RS's Avatar
What all involved in relocating the control arms, and did you weld the brackets or bolt?
Old Dec 20, 2002 | 01:52 PM
99Z28RS's Avatar
what about weld ins, do you have to have a shop cut the old ones out and weld the new ones in, nd what is usually preferred bolt, or weld.
Old Dec 21, 2002 | 12:59 AM
LS1Bird's Avatar
If you have bolt-on BMR's like I did >>
The hardest part of the install is cutting the old bracket that is currently on the car. The BMR won't squeeze over the old assembly, so the directions show you where to cut it.
If you have a Saws-All, no problem. Otherwise you are in for a LOOOONG afternoon!
Mike M
Old Dec 22, 2002 | 02:37 AM
99Z28RS's Avatar
ttt
Old Dec 23, 2002 | 06:57 AM
i bent mine with a screwdriver...
Old Dec 23, 2002 | 01:32 PM
Fulton 1's Avatar
Here's a good install doc on the bolt-ins. They're no big deal to install - just a little time consuming. As Mike mentioned, a sawz-all with a good blade makes short work of the brake brackets.
http://www.installuniversity.com/ins...n_brackets.htm
Old Dec 23, 2002 | 04:19 PM
99Z28RS's Avatar
is it better to get bolt-ins, or weld
Old Dec 25, 2002 | 10:52 PM
1 Stout Z's Avatar
Get the bolt on and have them welded later.
