Passanger side sits lower and hitting the rear wheel, please help
My car is lowered with Bilstein HD shocks+pro kit.
spohn weld-on relocation brackets+BMR double adjustable LCAs+double adjsutable BMR panhard rod.
For some reason my left side(passanger side) of the car sits lower,i'm saying that because when i go over bumps i'm scraping my rear right wheel(side wall) with the fender.
Throw at me any suggestions. We looked at the spring looks alright, shock "sprining" ok too.
Help <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Thanks !!!
Thanks !!!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Tom, a few things to look at, is the rear end centered ( panhard rod ), was the rear spring rubber installed, LCA adjusted too far forward, relocation brackets welded in properly. Good luck.
Al
Al
Panhard rod was my last hope, we have adjusted it yesterday
but you gave me an realyl interesting idea as for my LCAs, i can prolly adjust passenger side LCA so it will make my car a bit higher on that side.
What you thinkm it is even possible ?
Thank you !!!
Thank you !!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TomQ:
<strong> Panhard rod was my last hope, we have adjusted it yesterday
Thank you !!! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't think adjusting the LCA will make your carsit higher on that side, it would only bring your wheel foward or back ( depending on how you adjust it ). Your LCA should be the same length as the stock one, if your new LCA are the same length as the stock ones it won't help.
What kind of car do you have, SS, Z28, WS6...?, have you changed the size of your wheels/tires?
i ahev 2k1 trans am
tires on the back are 285/17/35...
i went with height adjustment kit from global west, will install it next week, should help...
i wish i knew that before...
<strong> i ahev 2k1 trans am
i went with height adjustment kit from global west,</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tom, what's involved in a Global West adjustment kit? Another thing that might have helped is a http://www.slponline.com/view_produc...RTNUMBER=80046 .
Keep me informed on your progress or lack of <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> .
here is what included into the kit
http://www.globalwest.net/camaro93.h...justment%20kit
the thing that i do not scrape my inner wheel wall, i scrape my external wheel wall (where it says the wheel specs). when i go over the bumprs, the wheel jumps in and hits the fender (i tried to roll the fender abit, didn't help).
I looked at those spacers i don't think those are for me and besides i'm not running so big tires like other people do. 285 isn't that big at all.
I will let you know how the install went.
Thanks
Thanks
<strong> here is what included into the kit
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Interesting, you want to lower your car and then you have to raise it so the tire doesn't hit the inner fender well.
I can't say about the Trans Am ( W6 ) but all Camaro SS's have bump stops installed at SLP,
when SLP gets the Camaro it has the smaller Z28 wheels/tires on it
I still think it could be your panhard rod needs adjusting, I'd come over and give you a hand but you don't live in the same state...hell you barely live in the same country <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
but you gave me an realyl interesting idea as for my LCAs, i can prolly adjust passenger side LCA so it will make my car a bit higher on that side.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The adjustable LCAs are of little use. If your car sits uneven, a tape measure will tell the tale. Its the springs or the sway bar.
I have seen many (most?) people adjust their APHR incorrectly. If you are having clearance issues, the APHR must be adjusted with the car supported by the axle with the rear springs removed from the car. Then you can spin the wheels and see where it's hitting.
If you still have interference issues, then you look at the spacers the factory installs on the cars with the 17" wheels (also available from SLP) which simply stops the wheel from moving up too far. Less wheel travel, fewer problems (but more bottoming out).
You shouldn't need to, but then you look at rolling the fender lip. I worry about rust in this area, so I avoided that.
Hope this helps.
DaveH
Hope this helps.
DaveH
