adjustable panhard rod?
<strong> I have lowered springs on all four wheels. Should I get an adjustable panhard rod & adjustable lower control arms. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Get the adjustable panhard rod ( BMR ), there's a good chance your rear end isn't lined up. Stay with the BMR boxed LCA, you could go with the poly/poly or poly/rubber bushings...either way would be an improvement over your stock LCA.
jay <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
at that, go one step further...get double sperical <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ....the panhard rod was the first "suspention" mod I did and I went with an aluminum (yes....aluminum) with double sperical rod ends. I was so impressed with the improvement of the cars handling that now ever part since then has had sperical rod ends <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> .
the rod ends on the panhard rod have little if any increase in road noise (its so far back and has limited movement). Lower controle arms are where you get noise (but I got used to those after a week also...don't even notice them now)
Chris
<strong> I have a double adjustable PHB w/ the rod ends - It came with the car. I just don't know how to properly adjust. What do you line up with, please any help would be greatly appreciated. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The best would be if you could put a straight edge along the drive shaft and ensure the rear universal joint is aligned 90 degrees to the axle tube. (like an "L" ).
Most people (including myself) just get down behind the car and adjust the rod until both tires are centered in relation to the body panels. The idea is to "even" everything up as much as possible. It’s really quite easy. Leave the car sitting on the tires (on ramps if you have them so you have room under the car) and just turn the rod one rotation (any direction) and see if that shifted the body the way you wanted. If it did..keep going....if not...back up one turn (to reach where you were) and then turn another turn. It just takes time. When you get everything finished....tighten the nuts down so it cant get loose.
Hope the length does not boor you...I just always like step by step instructions... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Chris
<small>[ February 11, 2003, 05:54 PM: Message edited by: 2001CamaroGuy ]</small>
<strong> adjustable <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> even not being lowered there is a good possibility that the rearend could be off some.
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Who makes the panhard rod you are purchased?
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2001CamaroGuy:
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Who makes the panhard rod you are purchased? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">sorry it took me so long to get back to you.....I got mine from Z rated motorsports
http://www.zratedmotorsports.com/
I looked all over their web site for it but they don't list it (don't list panhard rods) but they have a picture of it. I even found the recept from them.... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
They have two:
1) is nonadjustable....standard upgrade
2) is the one I have....very good
I would say call them. I got mine for $135 (10% sale at the time) so it would be something like $150 max....
Chris
