Harness bar???
Old Aug 4, 2006 | 09:54 PM
FredoCamaro's Avatar
Default Harness bar???
I can't find this anywhere I think it bolts to the rear shocks.....does anyone know where to find it?
thnx David
Old Aug 4, 2006 | 10:13 PM
saxd's Avatar
I believe its made by LG Motorsports. Sponsor --->
Old Aug 4, 2006 | 10:22 PM
Duffster's Avatar
I've got that EXACT one sitting in my GARAGE. . .took it out last week. Red and everything!
Duff
Old Aug 4, 2006 | 10:48 PM
fa63's Avatar
For some reason, that doesn't look like the LG unit. But I could be wrong.
In any case, think twice about running just a harness bar and 5/6 point harness... With those, you won't be able to slide around like you would with the stock belts in case of a crash, and that could potentially make matters much worse than they ought to be. Try at least a roll-bar if you want to run harnesses. Good luck.
Old Aug 4, 2006 | 11:12 PM
mitchntx's Avatar
https://ls1tech.com/forums/road-racing/551515-help-i-need-02-camaro-harness-bar.html
Old Aug 5, 2006 | 07:26 AM
Duff
Do you have any pics of it in your car??? Did you notice any improvement in handleing with it on?
thnx David
Old Aug 5, 2006 | 08:20 AM
Duffster's Avatar
thnx David
I don't have any pics IN the car, but I could easily snap some.
As far as the handling, I don't think it helped in the least. Not to be a bummer, but it is mounted to the studs used for the rear seat belts.
This is from the guy I got it from whom said it is the LG Motorsports G2 also.
Old Aug 5, 2006 | 10:09 AM
BitViper's Avatar
Right..
Not the G2
Is the G2
Old Aug 5, 2006 | 10:24 AM
MiaSSmaro98's Avatar
can u use the rear seats?like can u keep them this will be for a buddy because i have a 6pt roll bar
Old Aug 5, 2006 | 11:12 AM
BitViper's Avatar
Sparko makes somthing like this..this is NOT a Sparco model..but their similar
Old Aug 5, 2006 | 02:57 PM
Does anyone know where I can find any of these???
thnx David
Old Aug 7, 2006 | 05:56 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Well, the LG version would be found at LG Motorsports (Sponsor)>>>>>>>>>>
The others I have never seen before - would have to search web.
I can tell you that the rear seat is unuseable with the LG bar and the folding backrest will not work anymore either once it is installed.
None of these harness bars are meant as a suspension component and will do NOTHING for your suspension. They are a cheaper alternative to a roll bar in order to use harnesses instead of your stock seat belts.
You must evaluate the type of seats you are using with harnesses as well as the rear mounting points - there is a specified angle that the shoulder harnesses should be at as they cross over your body that directly relates to the rear mounting point. If this is not correct you can actually be hurt worse in a crash with the harnesses...
-Jay-
Old Aug 7, 2006 | 03:59 PM
GR33N GoblinM6's Avatar
I have that red one in the 1st pic... but mines black... got it on ebay for 125$.. its awesome
Old Oct 8, 2006 | 03:22 AM
SnakeStomper's Avatar
Searched e-bay, couldn't find that bar. Any links to any of the harness bars posted here? Thank you.
Old Nov 11, 2006 | 10:16 AM
TransAmNut619's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...5493&rd=1&rd=1
Old Nov 11, 2006 | 10:29 AM
Sweet! Do you guys know if you can have the back seat up with this bar on?
Old Nov 11, 2006 | 10:32 AM
Tainted's Avatar
yea but it would be hard/uncomfortable to have anyone sit in it anymore
Old Nov 11, 2006 | 10:35 AM
I would prefer it to be that way! ...lol But I just don't like the way the seats look folded down...
Old Nov 11, 2006 | 10:40 AM
Could just take the whole rear seat out
Old Nov 11, 2006 | 09:56 PM
subtlez28's Avatar
I just put mine in for races, and take it out when I'm done. I need my backseat 4 my kids. It only takes like 25 mins to swap out, less after a couple times.
