Slp bolt on subs???
Old Apr 12, 2003 | 09:37 PM
ZmeGo's Avatar
Default Slp bolt on subs???
I just installed SLP bolt on sub frame cons. and now I get a banging sound coming from the LCA area when I go over a big speed bump or into a hard turn. Doesn't do it all the time. What could be the cause???? Thanks guys
Old Apr 13, 2003 | 06:53 AM
DARK AGE 53's Avatar
Default Re: Slp bolt on subs???
Sounds like the LCA aren't torqued enough, torque specs are 80 ft/lbs if your tightening the head of the bolt or 60 ft/lbs if doing the nut. I'm not sure what your torqued the large bolts that came with the SLP sfc but 55 to 60 ft/lbs would be good, the tunnel brace bolts should be 25 ft/lbs.
Al
Old Apr 14, 2003 | 09:31 AM
RCMSSCamaro's Avatar
I have Re-toqued and checked everything on mine and it still rattles intermittently. I am certainly not saying you should not check your suspension, but it might be the nature of the suspension. I really dont believe that but I have'nt recieved a better answer or remedy. Hopefully someone will chime in that knows what it is.
Bob
Old Apr 14, 2003 | 02:24 PM
trackbird's Avatar
https://ls1tech.com/ubb/cgi-bin/ulti...;f=25;t=002297
Read my second post on this thread....see if it is the same problem....
Kevin
Old Apr 14, 2003 | 03:40 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RCMSSCamaro:
<strong> still rattles intermittently.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Maybe it's your heat shield?
Old Apr 14, 2003 | 10:54 PM
ZmeGo's Avatar
Well, I torqued everything down to specs, Guess what??? no more banging sound. Car feels nice and solid. Especially when turning hard. Great investment. I thought I had tightened everything up. Goes to show what a valuable tool a torque wrench can be....
Old Apr 15, 2003 | 10:17 AM
JPWS6's Avatar
How did you get the torque wrench on the bolts to torque down the lca's? I have a craftsman torque wrench and it won't fit between the frame and lca bolt with the socket on it. I am going to try a swivel socket, but was wondering what you used?
Old Apr 15, 2003 | 01:28 PM
I don't know what ZmeGo used but we used a crowfoot wrench with the torque wrench.
Old Apr 16, 2003 | 02:24 AM
ZmeGo's Avatar
I used a 3/8ths ratchet torque wrench and a shallow socket on the bolt head. I wouldn't use a swivel socket,it will break. Plus your torque setting will be off. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
