Is it bad?
Old Aug 17, 2006 | 09:50 PM
VenomInside's Avatar
Default Is it bad?
Not sure if this is the right place to put this but...
When I am stopped at a light and my foot is on the brake, the car still creeps as if your not pushing down hard enough (but I have the brake pedal basically to the floor)
Cause yea.... thats whats up with my car.
Thoughts?
Old Aug 20, 2006 | 04:55 PM
slow's Avatar
Either poor brake performance, or idle too high and getting stall creep due to a tight converter.
I assume the car is an A4, so both could be possible.
Ryan
Old Aug 20, 2006 | 05:30 PM
FDKSS's Avatar
Id check the break fluid first and start with replacing te master and slave for the brakes and see what u got after that.
Old Aug 20, 2006 | 08:43 PM
Ericbigmac83's Avatar
My car sometimes inches forward when im at a stop with the brake off, and i have a m6, its the weirdest thing
Old Aug 20, 2006 | 08:52 PM
00'WS6Rocket's Avatar
air in brake lines?
Old Aug 20, 2006 | 09:01 PM
Ralls's Avatar
Put it in neutral and hold brake to see if it still creeps. That will eliminate the question about torque converter or idleing high. It's probably air in the brake lines though.
Old Aug 22, 2006 | 04:10 PM
Throwing it in neutral made it stop
Old Aug 22, 2006 | 08:09 PM
Ralls's Avatar
Good, then your problem doesn't sound serious now. Its not your brake pads, no matter how crappy they are. It is most likely air in the brake lines. You can do it yourself if you know how. Just simple tools, but needs to be jacked up, and two people. If you get all the air out of the lines, and still doesn't stop good: Maybe a vacuum leak or master cylinder problem. Check lines first.
Mitchell
Old Aug 22, 2006 | 09:34 PM
Mitchell
Sweet. I'll check it out and let ya know. I'll most likely check it out tomorrow. Thanks!
