Bilsteins And Strano bars
Old Sep 3, 2006 | 04:39 PM
Giddswat's Avatar
Default Bilsteins And Strano bars
I just finished the install of the Bilsteins on my 2002 Z28, I also have the Strano sway bars. This is a great upgrade for a stock susp. It rides a little firmer, but in no way is it harsh. The sway bars were done first and there was a big improvment in cornering, control, body roll. With the stock decarbons still on the car you could still feel the car move around alot when cornering; With the Bilsteins installed this car handles! The bars and shocks really compliment each other, and I feel it was money well spent. I just wish my wife would feel that way, lol. Next up will be headers,cut out, tune.
Old Sep 4, 2006 | 12:11 PM
damon_Z's Avatar
I got the same setup on my 2002 Z28. My suspension mods are as follows:
Bilstein HD shocks, 1LE rear lower control arms and panhard rod, front and rear Strano swaybars.
All were installed at different times to see how each set of modifications affected the ride and handling.
The 1LE rear lower control arms made the ride stiffer by about 10%, but I saw no improvement in my 60' time at the dragstrip. I feel that they could improve dragstrip traction if I had better tires such as Nitto drag radials, because the 1LE bushings are solid and spherical while the factory bushings were not spherical and had equal-distant spaces between them and the control arms (to contribute to the comfortable factory ride).
I noticed no handling improvement with the Bilstein HD shocks, but they did make going over bumps feel less bumpy.
I noticed no handling improvement with the Strano front and rear sway bars.
Please keep in mind that I don't do spirited driving on public roads. I don't make road racing turns or anything of the sort. The only spirited driving I do is on the dragstrip where I go fast in a straight line. This should explain my slight disappointment in getting these handling modifications.
Old Sep 4, 2006 | 12:46 PM
hurley711's Avatar
Bilstein HD shocks from Strano the best mod I have done to date on my 300 mile a week DD
Old Sep 4, 2006 | 03:45 PM
Krab's Avatar
I'm glad you like that combo. I have the same set-up (Strano front/rear bars and Bilstein HD's) and can definetely tell the difference in handling compared to the stock components. I take it you're also on stock springs?
Old Sep 4, 2006 | 04:08 PM
BLK02TA's Avatar
I'm confused. You make it sound like your car is mainly a drag car? So why didnt you spend the money on a tq arm stuff like that, thats better suited for the 1/4??
Old Sep 4, 2006 | 05:19 PM
damon_Z's Avatar
I thought the handling modifications would actually make the car more fun to drive on the street. That's all. The torque arm is coming later...
Old Sep 4, 2006 | 05:24 PM
Foxxtron's Avatar
...the 1LE bushings are solid and spherical while the factory bushings were not spherical and had equal-distant spaces between them and the control arms (to contribute to the comfortable factory ride).
I'd say they're more cylindrical rather than spherical, but yes they're a more "complete" filled bushing than non-1LE.
Old Sep 4, 2006 | 08:15 PM
wannafbody's Avatar
35 mm ST bar
1LE front springs
Strano revalved Bilsteins on front
4th gen Bilsteins on rear
comfortable enough to drive every day
Old Sep 4, 2006 | 11:47 PM
RevGTO's Avatar
Pontiacerator
I noticed no handling improvement with the Bilstein HD shocks, but they did make going over bumps feel less bumpy. I noticed no handling improvement with the Strano front and rear sway bars.
Wow - I can't believe what I'm reading here. Rebound control with my Bilstein HD's is 100% better than my stock 50k DeCarbons, and dips that would cause my front air dam to scrape are now no problem. Major difference. I don't have the sway bars, but I have to believe they would help significantly with the excessive body roll these cars have.
Old Sep 5, 2006 | 01:46 AM
LS1TechRulez's Avatar
I dunno man I instantly noticed a difference in the steering with the sway bars. You dont have to be hitting corners hard to feel that difference.
Also the car feels a lot more stable when making lane changes on the freeway.
