thinking of swiching
i have in the near future a set of pacesetter long tube headers and maybe a true duel system... the main reasion that is am going to swich is becouse the inside corner of all my tires were to the wire in like 4 months... would this help or should i just give up on the lowered car and find some stock ws6 springs...
thank you for your time... As for the rear, you really shouldn't have to adjust anything other than the thrust angle. To change the toe, they would have to heat the axle tubes and bend them.
I took mine to a local shop and gave them these specs (shamelessly stolen from Trackbird):
-1.2 Camber
4.7 Caster
0 Toe
They gave me a printout when they were done, showing me where all the specs were.
-Mike
As for @nthony, that doesn't sound like a toe problem. If it was a toe problem, the outer (too much toe in) or inner (too much toe out) edge would be worn faster than the rest. The fact that the middle is wearing faster tells me your tire pressure is too high.
-Mike
-Mike
Of course, if you go with true duals, that's another matter. Someone else will have to chime in there.
-Mike
BOSS APPROVED!
