c5 brake upgrade with fbody rotors?
Hey guys, besides the c5 brackets and c5 rotors. Im gonna get fbody pads, do i need any other parts to make this work?
thanks!
thanks!
you can use your Fbody calipers, Fbody pads.. C5 rotors.. and mounting brackets to place the calipers out farther from LGmotorsports or UMI
C5 and Fbody calipers are the same.. the only difference is how they were made, one cast, one pressure cast.. so its not the caliper per-se but the placement of the caliper father outward in diameter to produce better stoping power.
your post thread subject is the reason for my post.. you dont use Fbody rotors..
Originally Posted by 92SilverSHO
ahh ok i have the trackbrackets from trackbird. so i have to use c5 calipers then?
http://www.frrax.com/rrforum/index.php?showtopic=8196
Hold on.... C5 rotors are exactly identical to Ls1 rotors other than the quality ?
I have a good set of low miles OEM ls1 rotors and I need to buy c5 rotors for a project.(non fbody)
I was gonna buy autozone rotors si I guess I am better off with good OEM ls1 rotors eh ?
What about the brake pads ? Are they the same ?
Originally Posted by johnpate01
Kore3 brackets, C5 abutment brackets, C5 rotors, f-body pads and calipers. I am VERY happy with my setup.
wait, you're using your F-body calipers with the Kore3 brackets? i thought with theirs you can only use the C5 calipers??? shoot if thats true.. im ordering mine NOW
