Any issues with drilled/slotted rotors?
Want to get them done, but I heard of stress cracking, fast wearing, etc. How hard are they to clean? I mean look clean, not sit there for an hour per wheel with a buffer, those days are long gone. Anyone have problems with them?
Make sure to get quality ones. Poor quality = cracking around the drill-holes over time. Another problem is weight. Even with drilled holes, some of these brakes are made with a lot of extra meat - which isn't necessarily a bad thing, but might be an issue for you? Take a look at auotzones' website and check out the shipping weight if you want some examples.
What do you mean to clean? What part of the rotor are you looking to clean? Just go for a drive and apply the brakes, that will clean the mating surface up for you. Also, do a search on slotted/cross drilled rotors, you will find a lot of reading material. If you want to bring your car to a stop, get quality blank rotors. If you want to look "cool", get some cross drilled/slotted ones, but fully expect them to create stress cracks over time.
Originally Posted by Xx01CamaroZ28xX
Over how long of a period of time?
Unless the reps from Baer and Brembo are all morons (which they're not)...cracking coming from the drilled holes is normal and it means the rotors are made correctly. I have cracks coming from every single hole in all 4 of my Eradispeed rotors, both sides. I sent Baer pictures of all the rotors and they said that they are completely normal and expected. They said the cracks that come outward from each drilled hole is how the rotors dissipate energy, heat and stresses. If a crack reaches far enough to go into another drilled hole, THEN and only THEN do you need a new rotor. Mine are 4 years old and the tiny cracks are the same size they were 5 months after I installed them. Brembo confirmed this because I called them right after Baer told me this. I think they both know what they're talking about.
And cross drilled and slotted rotors don't only look good, they are better than blank rotors. But only on a track. If its street car, all you really need is looks. They will also stop your car a tiny bit better than the stockers will. I know the Eradispeeds and others have the same swept area as stock rotors, but regardless of what anyone says....they are better and smoother, but just a tiny bit.
Get the Baer Erads...they look better than any other rotor out there, except the $5,000 Brembo's.
Originally Posted by mitchntx
So you clean all the little holes out after each use?
You have noticed they get clogged up with brake pad residue, didn't you?
And if clogged, what's the point?
Are you serious?
My holes are free and clear and I've never cleaned them excpet for a bath.
They dont cake up!!
Some of the **** you people come up with is hilarious.
First of all the thread starter says "have them done"..
BIG NO NO right there. You dont have your rotors cross drilled unless your looking to ruin them. Stock rotors arent meant for this.
Buy cheap *** parts and get cheap *** results.
My Baer eradispeeds came with the big brake kit. Best damn brakes I've ever had.
Yes they are made by the same people who makes our stock brakes and vette brakes PBR.
Honestly I'd love to see a caked drilled rotor. Next time you see this take a picture and post it, I've got to see this to believe it.
Originally Posted by 99blancoSS
Are you serious?
They dont cake up!!
They dont cake up!!
For daily use ... no doubt about the OEM Delco pads ....
Running Baer on all 4 corners for 3 years in Arizona 115 degree weather. Not one crack, cacking, or any other bizarre stuff mentioned above. The black on the hat has faded though..to be expected.
I talked to Baer since they are here in town and they said to definitely run the OEM pad. Dust stays down, easier on the rotor, no squelling. Said people who run the...(can't remeber, I think is was a color) pads will eat the rotors up.
From: Central Indiana Honors: 4th grade spelling bee contestant
The Baer Eradispeed isn't cheap. But you get what you pay for.
