Which shocks for BMR springs?
Sorry if I posted prematurely but I am fixing to go to work so haven't really searched a whole lot. I just bought the 95 Z in my sig and it has stock shocks and red springs all the way around. It appears that the springs are BMR as they are the only company I know that has red springs. (Let me know if they are something else.) I was wondering which shocks go well with these springs. I didn't want to buy a shock that didn't fit the spring. I was thinking QA1's up front so I could tune for the strip. Anything good and cheap for the back?
I had read a few posts about those shocks. I'll check them out. Perhaps the site will have the answer to my question of whether or not these have been revalved for drag racing.
Get the revalved Bilsteins. The car won't ride very well with stock shocks and you really need a shock that is setup to handle the new springs. I have Koni SAs with my BMR springs and the car rides great. I had to put my factory shocks back on for a short time and I hated it. You can use stock shocks and you may think it rides fine but trust me once you get a GOOD set of shocks on the car you won't know what you've beem missing out on
Originally Posted by BirdmanLS1
Sportlines are red. I think the prokit is red too... im not sure about the prokit tho. Sportlines are red for sure tho.
Car is definitely lowered. I'll have to take my other car and put it next to the red one to tell for sure. Hopefully when I get under it I can see a logo or something. Apparently the shock I choose will fit the springs as long as they're not stock.
Originally Posted by 01 Red WS6
Get the revalved Bilsteins. The car won't ride very well with stock shocks and you really need a shock that is setup to handle the new springs. I have Koni SAs with my BMR springs and the car rides great. I had to put my factory springs back on for a short time and I hated it. You can use stock shocks and you may think it rides fine but trust me once you get a GOOD set of shocks on the car you won't know what you've beem missing out on
Breezing through Summit's catalog, looks like Sportlines are red and Prokit is not. I know I don't have the Sportlines cuz the car ain't that low. Pretty sure I have the BMR springs. (Car is at a friend's garage or I'd go look.)
Vikingramair, how are the Koni's with weight transfer? Everyone has replied with a handling shock. I want drag racing! I know the QA1's are the best for that but I wanted to see if anyone was running them with the BMRs.
OK got a chance to call BMR. They said the QA1's will give out with street use pretty quick. Maybe that's why no one recommended them, lol. You just had to say it! They recommended Koni for street/strip with their springs.
LS1TECH Sponsor
And I'm glad to hear it. I also happen to agree. Issue is simple, these aren't drag springs, they aren't ideal for transferring weight anyway. Shocks are spring dampers, and drag shocks can't control heavy springs well in the first place. In tandem it's far from ideal.
__________________
LS1TECH Sponsor
Lowering springs in general aren't great for launching.... If you have them you could run them, but they are ultimately stiffer in the rear than other lowering springs which isn't great for weight transfer.
Koni's with those springs will work well. The hitch is I'm not sure the springs are ideal for what you want, or that any lowering spring, mine included, are the best for what you want. Biggest issue being I don't know exactly what you want, and can't know that from e-mail.
__________________
Thanks for the reply. I don't want a cornering machine. I just want a car that rides decent on the street but will transfer weight at the drag strip. I'm not necessarily looking for $$$ aftermarket stuff. I just want the best tradeoff for street and strip. I'm ready to ditch the springs if I have to.
LS1TECH Sponsor
Well, lowering springs aren't what I'd do on a car meant to launch. Ride and handling are still shock related and running Koni's is still the best choice, but you'd be better off @ the strip on a set of stock springs. And Koni SA's will allow you to keep the car a little lower even with a set of stock springs installed, other shocks won't.
__________________
LS1TECH Sponsor
Stock springs are softer and taller which helps weight transfer. The Koni's can be adjusted for the street performance you like best, but then turned down for maximum weight transfer at the drag strip. I think it's the ideal compromise solution for you.
__________________
