4 vs. 6 pistons?
The reason being that (use Wilwood calipers for example) the effective piston area of a 6 piston is limited by it's staggered bore vs. a standard 4 piston having symmetrical bore.
ex:
Wilwood SL6R bores are 1.62"/1.12"/1.12" which gives an effective area of 4.03"
vs.
Wilwood SL4R bores are 1.75"/1.75" which gives an effective area of 4.81"
Now when one runs the numbers of line pressure, rotor size, pad compound, etc., the differences are quite a bit.
As I understand it, the entire idea behind having the staggered bore of the 6 piston is to help with pad wear under extreme conditions but how serious is this? At what point does the 6 piston actually become better than the 4 because based on numbers only, the 4 would result in a much higher clamp load at the same pedal pressure.
How much more clamping force do I need?
and I can't, I don't have power brakes.....but that wasn't the question....
so thanks for the pointless post....
Well, it might have also been helpful if you had mentioned that you were running manual brakes on this car in your first post. It would have made your first post just a bit more useful to anyone who was trying to help solve problem. That little fact changes the question considerably. I was originally going to explain that the 4 piston kits could pull the bias forward a good bit (unless the rotor size was adjusted to keep things balanced), however, you probably need outright clamp load more than a power brake car. But we wouldn't know that unless you considered it important enough to tell us in the first place.
This is one of those rare cases where I'd suggest getting Wilwood on the phone, telling them what master cylinder bore size you have and what car, etc. They will probably ask for a bunch of information and try to guide you towards something for your application.
If this is a drag car, you might also look up Aerospace brakes. However, if it's a street car as well, be careful which brakes you buy from them. Make sure they know that it's driven, how far and how often.
Clamping load isnt the 'tell all' about how your system is going to perform. Just because your numbers show the posibility of a higer clamping load, doesnt mean that the caliper is going to be stiff enough to harness that pressure/force.
Anyway, how serious is pad taper ?? Well, it can happen at street level braking, all the way up to professional track racing.
The six piston calipers have inhearent props from many different view points. Reduced taper, larger pads for better PSA to SA and their natural ability to use a larger rotor. Just the mere fact that the load can be spread over a greater area by splitting up the force, to the pad itself, from mulitiple pistons brings more light on how pad surface area to swept area lends much more to your question than that of simple clamping force alone.
I'm running Wilwood SL6 calipers on my car. For autocross use, the pad wear was decent, but as I switched to more aggressive pad compounds and did more street driving, I found that the "grip" of the pads would still pull them towards the rotor and they can still wind up heavily tapered. With harder use, the differential bores will help keep the pads wearing even, with light use, or brake pads with high friction coefficients, you can still see considerable pad taper. The differential bore essentially a "best guess" at what will keep "pad a" wearing well under "condition b". If you fall outside that range, as I did, you'll still see pad taper. So, my experience says that you shouldn't get too hung up on 6 piston vs 4 piston for a car that sees street use. For all out racing when every stop is nearly max effort, it can work better. But on the street an aggressive pad will "work" well enough at very light pressures that the main benefit of the staggered bores is lost.
Not only was his reply not helpful in answering the question (it didn't even attempt to) but was pretty much a "why change anything" answer.
I never stopped to think about the fact that a 6piston caliper has a larger pad which can thus have more area to grab the rotor.......hmmmm....
the reason I didn't go into specifics about MY car was because I was looking for WHY and HOW different calipers (specifically piston number comparison) perform differently and their advantages.....I knew if I started putting all this info in about my car, people would be more likely to just give "advice" vs. "information"....
We are talking about the leading edge of the pad "digging into the rotor" and thus wearing faster correct? SOMEWHERE (way back in time) I seem to remember reading something about some race teams actually "cutting/machining" their pads to have less "area" on the leading edge to help prevent this "digging effect."
I'm currently fabbing up a 3-link 12bolt (extended LCAs and a centrally located UCA off the center section). The pedal assembly is a Wilwood triple master setup with a 6.25:1 pedal ratio, a 7/8" bore clutch master, and then was THINKING 1" masters for the brakes (though that is still to be finalized). As far as the shocks/springs, I'm currently running LGs Coilovers but once I really get into it, I MIGHT play with the spring/valve rates (time will tell).
Again, this is just my experience, others may have different results.
IF I understand what you are saying, at the "typical" lower pedal pressures and less aggressive pad compounds found on "street vehicles", the differential bore does not seem to make much difference as pad taper (and overall pad wear) are quite low.
HOWEVER under heavy load/aggressive compound conditions, the staggered bore tends to help the pad "live" a bit longer (not taper as fast).
Am I fallowing correctly?
PS. I guess I was a bit "blunt" on my first reply but it felt like his reply was more of a "cut/changing brakes is stupid" reply vs. an attempt to actually answer a question (I get very pissed off when I see people just post "crap" when others are honestly looking for info/help).
My response was an attempt to get you to think that there more to braking performance than just clamping force.
You shouldn't get so worked up over insignificant things like the internet.
Am I following correctly?
What I was trying to say is that using a less aggressive pad on the street will require more pedal pressure (clamp load) to achieve the desired stopping force. This will help balance the pad wear by making the differential bore sizes work properly (or closer to properly). If you use a really grippy pad, you don't use much pressure (those pads stop well with "light" contact) and they will grab and taper. If you are on track and using high pressures to stop quickly, you can also use the more aggressive pads since you'll be using enough pedal pressure.
Did that help?
Did that help?
NOW I GET IT!!!!!!!!!
lol...thanks...
4 pistons have more "clamp force" (actual conversion of hydraulic pressure to mechanical pressure)
6 (or 8) pistons have more pad area (more friction surface to act against the rotor) and better modulation/feel
so in the end, while one might "loose" some clamp force with more pistons, they gain more contact with the rotor and also a heightened ability to control the application of the pressure
I think I'm getting the idea here....
An explanation. "Effective Piston Area" is calculated on a 2 piston "slider" type caliper (like the F-body and C5) by doubling the piston area measurements. Meaning, you'd calculate the Corvette caliper as 4 pistons at 40.5mm each. This is because the pistons on one side pull the opposite side into the rotor, this causes those pistons to use twice the travel and use the front of the piston and the rear of the bore (equal and opposite reaction). So, you count them twice. The Wilwoods are more straight forward, you just add up the piston area of all of the 4 or 6 pistons.
Also, the pad area isn't figured into the braking calculations. However, more area can help to control peak temperatures seen by the pad/rotor interface. This can also help modulation and fade resistance, etc. So, though it doesn't specifically figure into the math, it can have a very real impact on performance. This is also why many prefer "tall" pads that sweep a lot of area (from the hub to the edge), they spread the heat out on the rotors surface since rotors do not "wick" heat into the center quickly (instantly?) enough to cool in real time while stopping. This is not to say that the center of the rotors won't get hot, just that the most effective part of the rotor (as a heat sink) is the part that comes directly in contact with the pads.
Also, the 6 pistons can often use a series of staggered bore sizes to reduce pad taper under hard use. As we stated, this isn't as useful under light brake applications, but can be a great benefit under track conditions.
