IM ordering
Here is a picture of the brakes one of the members of corvette forum runs on his C6Z06 race car.
Notice the hugh blank 2piece rotor.
http://stoptech.com/tech_info/The%20...%20Systems.pdf
http://stoptech.com/tech_info/wp_warped_brakedisk.shtml
http://stoptech.com/tech_info/faqs.shtml#15
http://baer.com/Baer_tech/FAQ.html
http://www.tirerack.com/brakes/tech/index.jsp
http://www.stainlesssteelbrakes.com/tech/
Hate to bring this up, but a fact IS proven (thereby a FACT and not a theory). Pet peeve. Sorry.
Just take a few minutes of your valuable time and browse these links and then maybe things will make some more sense. While there are certainly other informative sources, I think that these links should cover a good bit...
I am gonna add this though, because it makes me laugh and a few people here will laugh with me. If anyone that doesn't know this thread, read it and be amused and maybe learn a thing or two.
http://corner-carvers.com/altimathread.php.html
Jon
I have worked on cars just as long if not longer than some of the members have been alive and or driving depending on thier age. You are not showing me anything at all. This is my third F-body and i on average own them for 5 or more years before I move onto the next one.
I never had rotors on my 89 Formula 350 ever warp in as little time as the ones on the 2001 Formula did. Then the dealer replaced all 4 of them with brand new ones at less than 5000 miles just to have the new ones do it again under 10,000 miles.
Hmm, then did like everyone said and used some of the Autozone blanks and they were not any better.
Once please "show" and or "educate" me cause it seems I must be slow compaired to all of the more knowledgable ones on here that believe everything they hear and or read on the net.
Proof proven fact and you can say what you want, I have had way less issues with the drilled rotors on this car than I ever had with the blanks. I have not changed my driving style or anything else that can be atributed to the fact that the drilled rotors have not warped.
Now maybe if someone wants to spend alot more money for thicker blanks that Brembr offers but why? I only spent $250 on the complete set of the powerstop drilled rotors 3 years ago well before anyone was getting on the web telling people that drilled rotors are soo bad.
So please educate me and give me a clue ol mitchie poo...
A clue is that using a car on a road course, like this guy is intending to do, will REQUIRE you to pull the tires and do brakes very frequently. If you are lazy or unmotivated or clueless, maybe you should stick to watching races on TV. I've heard brakes don't wear watching TV. My Sundays are spent at the track ...
Your pimp, bling-bling, driveway jewelry brake rotors won't make the job any easier or less frequent. It WILL drain the bank account, though.
And if a person who does take his/her car to a road course often, will put the car on jack stands, take a hand full of wrenches and nut-n-bolt the car, stem to stern, to make sure the car is reliable and SAFE.
Consider yourself schooled and owned, squeakyws6.
https://ls1tech.com/forums/suspension-brakes/604066-what-s-best-flat-washer.html
Im gona run teh cross drilled and slotted on street. it isnt going to affect performance that much.
pn the track I will use autozone blanks, nd keep the stockers for spares, then change them at home.
http://www.installuniversity.com/ins...ds_mwarren.htm
And burning up caliper seals with brake heat ...
http://www.installuniversity.com/ins...er_rebuild.htm
hmmm ... I've owned you twice in one thread!
Mods, have mercy on Squeaky and
... Im gona run teh cross drilled and slotted on street. it isnt going to affect performance that much.
Many people in this thread are 100% correct about what can and usually will happen on a race course.
The bottom line is this. Drilled rotors can and typically will crack under hard use. Track use is hard use and if the track use is hard enough, they will crack just like the picture of the one I posted (which was cracked on the street). It was no coincidence that those cracks ran right through three of the holes in the rotor facing. With that said, if you don't run them "hard enough", they can work ok. They won't stop you any better, they are no miracle cure, but they can get the job done. I never said that drilled rotors will instantly explode when you drive the car with them, just that they can crack and in some cases throw off chunks of rotor which can really make a mess of things. If you know the risk and decide to take it, you've made an informed decision. If you choose to ignore it and have a failure, you made a choice. I'm just trying to prevent the typical misconception that drilled rotors are a magical upgrade. They aren't. They are cosmetic and only needed for appearances these days.
I might have agreed that he sounds pretty convincing at times, but then he said this:
Today we typically see fade due to overheating the pads (pad fade), but not due to the gas like outgassing could cause. Brake pads have a specific temperature range that they work in. If you get above or below that range, they don't work well and sometimes they don't work at all. So, if you overheat a pad, you can cause it's friction levels to drop off dramatically. This is the standard issue brake fade seen with most modern pads. Or, you can see fade from boiling the fluid. If the fluid boils, it turns to vapor in the lines. Vapor is compressable. So, you wind up putting the brake pedal on the floor and the car doesn't stop. The problem is that you can't move enough fluid to compress the boiling fluid back into a liquid. You'd have to pump the pedal far faster than humanly possible to compress the gas that forms when the fluid boils. It takes far longer to reach this condition, but it can be done. This is why we suggest fresh brake fluid for a track day. Most forms of brake fluid will be hygroscopic, it means that they absorb water from the air. As brake fluid becomes saturated with water, the boiling temperature of that fluid will decrease. So, by running fresh fluid, you can make sure you are getting the highest possible boiling point from your fluid. This isn't so important on a run of the mill street car (though it's a great idea), but on the track you run the risk of exposing any weakness. If your fluid is old and the boiling point has dropped, you run the risk of finding that out when you'd least like to have such an experience.
Secondly, iron conducts and absorbs heat far better than air. If you want to stop the car, you have to turn kinetic energy into heat. The heat is stored in the rotors during the stop (yes, airflow does get rid of some of the heat in real time, but most of it leaves right after the stop). If you are trying to cool a rotor by letting heat escape through the holes, you are wasting stopping power.
Consider this. If the heat is going to "escape" into the center of the rotor, how do you think it will get there? When the pad is covering the hole, there is no friction where the hole is. And, there is no airflow when the pad is blocking the hole. So, the hole doesn't get very hot. It will see some heat that's radiating from the solid mass around it, but there won't be much heat "escaping" into the rotor through that hole. Holes are full of air, and you can heat air, but not nearly as well as you can heat iron. Apparently there is a magical breeze that's rounding up all the heat on the surface of the brake pad and just waiting to wisk it off through those holes to cool the pad surface.....
Yes, there might be some radiant heat that's absorbed by the veins in the center of the rotor, but it's ineffecient to try to transfer heat through air instead of direcly to the metallic surface of the rotor. So, that's not much of an option for additional cooling. And, as I said, when the hole is under the pad, there is no airflow, and since holes are lousy at transfering heat (or making any since they have no friction since there is no metal there), once it's uncovered, the "hole" isn't hot, the surrounding metal is, but the hole is doing very little since air can't absorb nearly as much heat energy as the much more dense iron can.I'm glad that sneaky had good luck with his drilled rotors. But that does NOT make them the holy grail and they are most certainly not a good idea for hard use applications.
There are many in this thread who spend a large amount of time at race tracks and we know what happens or can happen because we've seen it happen. This isn't arm chair quarterbacking, this is actual experience talking and trying to save you time, money and frustration. In the end you are going to do what you like, but we can say that we honestly tried to share what we've learned the hard way.
Anyway, I'm headed to bed. Night!
If you both are soo much older than me then act like and act like a adult and not some pimpled face 16 year old driving his first rice car with a 4ft tall rear wing and NOS stockers all over the car.
80% or more of people on this board are going to street drive their cars, very few have the money needed to head to track days on a regular basis.
You both get in threads telling people that drilled and or slot cut rotors are worthless for the street and to run blanks, but yet alot of the people running those cheap blanks are right back on the forums talking about how they are warped already and what is the next step. I waqs one of those people that many years ago listened to people like both of you.
Your track expiriences may show and or say that blanks last longer and or hold up better at the track, but I see plenty of people at our local SCCA events and at Hallett running drilled rotors with no issues as well. Unless someone has the fund to run high end blanks, driller, or slot cut rotors then you can only expect a marginally made product to do only so well before it fails unlike its high end counterpart still holds up to the abuse.
I am not going to keep on internet arguing with you two ninnies. If it makes you look better on the forums and or your local forums, so be it. I am a better person than that and it does me no better personally or professionally to act like and *** instead of a adult on a open forum that thousands of people visit. All it does it tells people that a bunch of immature people post on here instead of knowledable ones.
LSgun I hope you got whatever info you need and most of all hope you have fun at your track day. That was all this thread was about and intended for before myself and the above posters when on our childish rampages and hijacked it.
I am sorry it got out of hand and hope you have some fun at your event.
Todd...
was even there to help. After that, I think you've done most of the name calling here.I guess this might be considered an insult, but it was really the easiest way to say what I meant.
I really think you just want to argue, but they is ok if that is your porogative, but so is being a ***** like you are demonstrating in front of everyone right now.
Dont give someone crappy advice and tell them they can go to the local auto parts store and get blanks that are just fine, there are just as many posts on warped blanks for Autozone and any other parts retailer as there are of people having cracked rotors.
Why dont you act like and adult and not some internet punk?
I tried to explain:
Geez, we get touchy don't we. It's kinda fun to poke some of you guys with a stick and wait for the insults. Again, you missed the sarcasm about my pansy comment. The point was that you are obviously not driving like an asshat on public roads, and if you don't, those rotors tend to hold up just fine. If you go beat on them hard enough, they can, and will crack.
General info:
One of the worst things you can do to brakes is park the car with them hot. That will warp more rotors than anything else. If you come sliding into a parking lot (late for work?) and just park the car, the caliper and brake pads help to keep the temperature elevated in the part of the rotor under the brake pad. This causes the rotor to cool unevenly. Iron has a high level of internal stress. This stress is similar to an ice cube when dropped into a drink, the internal cracking that you see in the ice is similar to what causes a rotor to crack. After enough heating and uneven cooling cycles that stress can also allow the metal to change shape, or, if you get them hot enough, it can change the iron over to "cementite". It's a change in the structure of the iron that is caused by extreme heat. Cementite is harder than iron and will wear at a different rate. So, if the pad and caliper area holds the heat in long enough for a change of state to occur on that portion of the rotor, you'll have a rotor of uneven hardness that will wear at different rates. This can show up as a warped rotor as well.
Info here:
http://metals.about.com/library/bldef-Cementite.htm
http://www.answers.com/topic/cementite
Meaning #1: the iron carbide constituent of steel and cast iron; very hard and brittle
Synonym: iron carbide
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
About 1/2 way down the page, you'll find this (but I recommend reading the whole article):
Anyway, that's enough tech for one thread. If you can't find the information here that allows you to make an informed decision one way or the other, it's not going to matter if we keep going. I hope your track day goes well and you have fun during your outing.
It's also obvious that you will spend quality time penning a long non-responsive response to the links of tech you have so openly asked for, but haven't read. Strike 2 ...
If you go back and read, you will see numerous times we have attempted to draw the distinction between track use and street use. You don't seem to get it. Strike 3
Your sad attempt at insulting me (us) is very humorous in that you can't seem to find that button to spin me (us) up. But keep trying slugger.
Right now, TB and I are just having fun at your expense. It's quite entertaining and will continue till we get tired of playing with you.
And sneaky, the point of this forum is for the exchange of knowledge and information. If you cant be open minded enough to listen to what other people have to say, and listen to reason, then maybe you shouldnt be here.
(a nice way of telling you to stay out of this thread or there will be bans)
Wow thats a lot of info.
Oh btw the Summit slots are very short and only 4 of them, plus there arent many drills on the rotors either, compared to some I have seen. So I should be good on the street, just for looks.
Again, we didn't really say that drilled rotors are bad on the street. Our goal is to educate people that drilled rotors won't make your car stop any better and that they can (under the right conditions) crack. Once a rotor cracks through to the edge, it goes in the trash. That is standard practice for brake rotors. If rotors are sufficiently warped, or cracked through the edge, they are "done". Toss them, start over. Once you understand this, you are free to decide if drilled rotors are worth the trade off they present. They look cool (they do), they can crack (not good), they can grind up brake pads and make extra dust (which many already complain about), they cost more (and may crack and become junk). If you are aware of those issues and decide to run them on a street car for appearance, then you have made an informed decision and I'll not talk you out of it. I'll only attempt to talk you out of it when you are buying them for the wrong reasons. This is an effort to save you time, money, and frustration. Once you understand (and reading those tech papers will explain a lot), you are free to spend your money however you'd like. All we're trying to do is educate people so that they can make an informed choice.
I hope this has been helpful despite the little side trip we've taken.
Have fun at the track.
Jon
Yes I know that( about the cracking). I did take a brake class afterall. I guess my teacher wasnt upated with teh slotted rotors info we got, or I didnt pay enough attention.
Anyways Its time for manual trans ( 2nd time) and cylinder block rebuilding class next semester!
and thanks to mitch and Jon B also. and everyone else.
Happy New years.
