installing bolt in subframes???
Old Jan 2, 2007 | 04:55 PM
transambandit's Avatar
Default installing bolt in subframes???
how do you guys get the front part bolted up, i stuck the bar for the bolts in the little slot but how do you get it to stay in place so i can get it bolted up.
Old Jan 2, 2007 | 04:58 PM
3.4camaro's Avatar
stick your finger up there and hold the bar. get both of them threaded so itll stay in place when you tighten.
or go get the welder.
Old Jan 2, 2007 | 07:28 PM
sixvi6-camaro's Avatar
I ran the bolts for mine through the threaded bar a bunch of times and put some oil on them to make installing them as easy as possible.
Old Jan 2, 2007 | 10:04 PM
VIP1's Avatar
Copy & Paste Moderator
Here is the write-up I followed when installing my SLP SFCs:
http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm
Old Jan 3, 2007 | 01:18 AM
matts22's Avatar
I didn't have any problem holding it with my finger through the opening and just pushing down to get them both started. With both started, it isn't going anywhere.
Old Jan 3, 2007 | 05:35 PM
SS1875's Avatar
Try a small screw driver in one side to keep it alligned and feed the bolt through until it grabs.
Old Jan 13, 2007 | 06:09 PM
well i spent an hour trying to get these damn things on, my fingers dont fit, they arent long enough to hold the bar down, anyone else have any other ideas?
link doesnt work
Old Jan 13, 2007 | 08:25 PM
3.4camaro's Avatar
try and thread both bolts at the same time, raising the bar up so that its weight rests on the bolts. idk man, i dont have big hands, i just stuck my fingers in there
Old Jan 13, 2007 | 09:12 PM
VIP1's Avatar
link doesnt work
It did when I posted it.
But it doesnt now...damn.
