View Poll Results: Is a Driveshaft Loop Important?
Yes, you should get one!
118
86.76%
No, there is no need for one.
18
13.24%
Voters: 136. You may not vote on this poll
How important is a Driveshaft Loop?
Old Jan 6, 2007 | 02:00 AM
revtime's Avatar
If you ever break a driveshaft or bust a Ujoint you will be glad you had a loop.
The damage to the bottom of the car can be significant.
I have dropped a driveshaft or two in my travels..... I won't run a Hot Rod without one.
I too have a Lakewood unit. Best one on the market and its the cheapest one too.
Old Jan 6, 2007 | 07:05 PM
jetlag's Avatar
Definately. I had one installed on my Mustang GT...but I was running slicks.
Old Jan 7, 2007 | 02:55 AM
flyin red TA's Avatar
I split a DS right down the middle with no loop. It now looks like something from Robot Wars got freaky with the underside of my car.
Old Jan 7, 2007 | 05:01 PM
nick_4.8sierra's Avatar
^^^ Dude, that sucks!
Does anyone know where I can get my DS balance checked & about how much it costs to get this done?
Old Jan 7, 2007 | 05:29 PM
LilSlo1's Avatar
Originally Posted by Demon Of Dreams
anything under 11.99 requires a loop I believe
13.9 and faster only if you are on a non DOT slick.
NHRA does not require a drive shaft loop as long as you are on a DOT tire (example: ET street or any drag radial) until you are running 11.49 or faster.
Old Jan 8, 2007 | 01:05 PM
Ripper415's Avatar
Originally Posted by Fulton 1
Another vote for the Lakewood loop. Its cheap, can be installed without removing the shaft (although it may take a little patience), bolts to the existing tunnel brace attach points, gives excellent ground clearance, AND is quite tolerant to most exhaust setups including true duals.
Link: http://www.jegs.com/webapp/wcs/store...0002_751248_-1
in that link the camaro one for $51 only goes up to 01. Since I have an 02 should I get the universal one for $26 and would it perform as well as the camaro specific one?
Old Jan 8, 2007 | 01:15 PM
Fulton 1's Avatar
No, do not get the universal one. Get the one listed for 93-01 and just assume that it says "93-02 Camaro/Firebird" because '01 and '02 are identical.
Old Jan 8, 2007 | 01:55 PM
chino_man279's Avatar
Originally Posted by nick_4.8sierra
Where can I get the DS balance checked at?
Thanks,
Nick
Nick, I take my driveshafts, flywheels, clutches, etc...to a local transmission shop. I would imagine any trans shop should be able to balance a driveshaft in house. Also any automotive machine shop should be able to do it also.
Old Jan 8, 2007 | 05:08 PM
Ripper415's Avatar
damn, i figured that was just a misprint but at the same time i was kinda hoping i could get the other one and save $25 lol
Old Jan 8, 2007 | 11:25 PM
DONAIMIAN's Avatar
where in texas are you
Old Jan 9, 2007 | 10:09 AM
Between Houston and San Antonio. I went to Houston last week, went to First Colony.
Old Jan 10, 2007 | 03:03 PM
  #32
koolaid_kid's Avatar
I like the Lakewood piece because you can install w/o removing the driveshaft. However, I prefer my BMR piece because I do not have to worry about the shear forces applied to the bolts on the Lakewood piece if the driveshaft fails. I would rather spend an extra hour just for peace of mind.
Just my opinion, yours may vary.
Old Jan 10, 2007 | 04:39 PM
  #33
Exactly what I was thinking that's why I think I'm goin with a one piece loop. Looks like if the DS came loose it would bust the small bolts on loops like the Lakewood. Just my thinking.
Old Jan 12, 2007 | 07:46 PM
  #34
James Montigny's Avatar
Easy install, cheap peice of mind.
Mine is attached to the crossmember that came with my torque arm
Old Jan 31, 2007 | 01:26 AM
  #35
TryingT/A's Avatar
I have the lakewood and from the picture, it does not look like it is gonna fit because in my borlamouth exhaust, the muffler is at the front of the driveshaft, where the ds loop would go. Would bmr fit?
Old Feb 9, 2007 | 07:34 PM
  #36
Black02SLPSS's Avatar
Its better to have it and not need it, than need it and not have it. If i were to keep the aluminum ds thats on my car i would probably get one but im lookin to get a chrome moly one still may get one but i havnt heard of anyone breakin a chrome moly ds on a street car before. just on the rock crawlers when they take a 10 foot fall and land perfectly on the ds.
Old Feb 9, 2007 | 07:43 PM
  #37
Slowpoke310@APF's Avatar
well earlier today my driveshaft ripped off at 85mph on the fwy, came off the differential end, fortunately (if at all i can actually say that)
i have a slp driveshaft loop (not installed, but im sure u can guess i will) but have been told that they wont fit verts
anyone know if this is true
and if so what brand will work?
Old Feb 11, 2007 | 09:51 PM
  #38
97blkz's Avatar
When your cars *** come a foot up in the air you'll have wished you had got one. Happened to me and I feel lucky with mimimal damage!
Old Feb 12, 2007 | 05:17 PM
  #39
mike#9's Avatar
cheap insurance...get one
better yet.....get a tunnel mounted torque arm with a built on loop
Old Mar 17, 2007 | 09:56 AM
  #40
2QuickZ's's Avatar
anyone know if this is true and if so what brand will work?
I had an SLP on my old 94 'vert. I don't remember having a problem with it. You may need some longer bolts. They say it won't fit because verts have an extra stamped X brace that uses the same mounting brackets. Since the base of the loop is thicker and heavier duty than the stock piece you can either leave the X brace off or bolt the driveshaft loop between the X brace and the mounting bracket on the floor board (hence the longer bolts).
