View Poll Results: Is a Driveshaft Loop Important?
Yes, you should get one!
118
86.76%
No, there is no need for one.
18
13.24%
Voters: 136. You may not vote on this poll
How important is a Driveshaft Loop?
Old Sep 4, 2007 | 05:03 AM
  #61
waldershrek's Avatar
I think it would be kinda cool to see a car "pogo stick"!
Old Dec 5, 2007 | 05:16 PM
  #62
2002BlackSS's Avatar
Not if you're in the car...
BTW, I've got a G2 DSL (made by LG motorsports), and it fit nicely and is 2 piece, so it didn't need to have the driveshaft dropped to install. Unfortunately I don't have pics, and it seems they discontinued it.
Old Dec 5, 2007 | 11:07 PM
  #63
sixvi6-camaro's Avatar
Originally Posted by 97' Z28
The only thing about using the Lakewood is that you have to remove the seats and carpet. After that you have to drill holes in the body to bolt the loop to. If you go with the SLP it just bolts right up. Either way you go they do the same thing.
What?? what did you have to do all that? Mine bolted right into place.. its a direct replacement for the stock tunnel brace.
Old Dec 20, 2007 | 07:25 AM
  #64
Burnout4200's Avatar
I feel that for the money, a DS loop is well worth the peace of mind. Just my 2 cents.
Old Apr 8, 2008 | 08:35 PM
  #65
INMY01TA's Avatar
I have the SLP ds loop. Very nice piece. Fits fine with my long tubes.
Old Mar 7, 2009 | 09:33 PM
  #66
01350ta's Avatar
I have a BMR, good solid piece, i think money well spent.
Old Mar 8, 2009 | 02:07 PM
  #67
35th SS's Avatar
lakewood dsl on the 35th and spohn built in on the t/a on the blk one.well worth the peace of mind.
Old Mar 8, 2009 | 03:14 PM
  #68
riceburnerZ28's Avatar
I have the lakewood loop and it saved my car a lot of damage when my ds broke ! yea I know it's dirty lololol
Old Mar 8, 2009 | 04:47 PM
  #69
jrob56's Avatar
does anyone have a picture of the lakewood dsl installed? will it work with tsp true duals?
Old Mar 8, 2009 | 04:56 PM
  #70
Cobra Commander's Avatar
That depends on the driveshaft. If I had a carbon fiber unit I wouldn't bother.
Old Mar 9, 2009 | 10:34 AM
  #71
Elliott's94Z's Avatar
Originally Posted by Fulton 1
Yeah, its like the old gun argument - you either don't need one at all or you really, really need one...
That's no argument in my book...you really really need one
As far as the safety loop goes I would invest the $45-50 for one
Old May 23, 2009 | 12:20 AM
  #72
DropTopBird's Avatar
I went with a UMI torque arm w/ the DSL. I figured why not get one if Im going to be replacing stuff in that area anyway. You might never need it, but if for some reason you do youll be glad you had it.
Old May 23, 2009 | 03:02 AM
  #73
ZMONSTER!'s Avatar
Bump for pictures of the Lakewood piece mounted, preferably with TD's
I have a custom made set, so Im not too sure if the lakewood piece will fit...
Old Jan 28, 2014 | 04:30 PM
  #74
calgary_z28's Avatar
Originally Posted by 2001z
I want to put a ds safty loop on mine but i had a slp loop and after i put my long tubes and headers on it wouldnt line up with the holes becouse it was hitting the y-pipe I am not sure what to do. i thought about making one but not sure
Bump from the crypt. Same scenario for me. Although my 98 Z has the steel driveshaft. Should I really be worried about breaking that on street tires/bolt on's? I've never read about anyone here breaking the oem steel DS. Debating whether or not to just get the UMI loop for peace of mind.
*anyone know where to get the 4 bolts to bolt in the loop? I threw mine out on the stocker after I installed my longtubes/ory..
Old Jan 29, 2014 | 10:17 AM
  #75
INMY01TA's Avatar
Hardware store.
Old Jan 29, 2014 | 11:14 AM
  #76
Originally Posted by INMY01TA
Hardware store.
Cool..but what size are they? I don't have any of them to
compare sizes.
Old Feb 2, 2014 | 09:34 AM
  #77
alex_lavier's Avatar
It adds additional safety for speedy drivers. It maintains the drive shaft into the right track.
Old Feb 2, 2014 | 10:05 AM
  #78
Carguy8888's Avatar
I snapped my rear u joint, ruined my drive shaft and beat the snot out of the bottom of my 69 shifting from 1st-2nd at 6k+ entering a parkway by myself after a nice launch. Yes I had a loop. The thought to myself was this is not good the second after the star spangled banner ended. I thought I blew the motor until I got to look under the car and said whew. I saved the mangled U joint after I sold the car for a paperweight.
Old Feb 2, 2014 | 10:15 AM
  #79
98CayenneT/A's Avatar
compare sizes.
8 mm bolts
Old Feb 8, 2014 | 01:34 PM
  #80
Originally Posted by 98CayenneT/A
8 mm bolts
Thank you!
