How important is a Driveshaft Loop?
http://www.mofbody.com/forums/viewto...ken+driveshaft
Those suckers will break and bounce around the tunnel like crazy.
More pics of the tranny (or what's left of it)
http://www.mofbody.com/forums/viewto...933&highlight=
I am not sure what to do. i thought about making one but not sure
I am not sure what to do. i thought about making one but not sureBMRs works nice, and the one I got from Spohn fit my JetHot Hookers perfectly.
There are several others on the market with a 1-2" dip.
i have a slp driveshaft loop (not installed, but im sure u can guess i will) but have been told that they wont fit verts
anyone know if this is true
and if so what brand will work?
NHRA does not require a drive shaft loop as long as you are on a DOT tire (example: ET street or any drag radial) until you are running 11.49 or faster.
Just put one on the car. Its one of those no brainers.
what about behind it
Anyone have any recommendations for a loop with Borla? I'd rather not have to remove the driveshaft....(the lakewood looks nearly Identical to the Spohn...)
That flat piece of stamped steel might actually have some rigidity in the horizontal position...
And how low does the DS loop hang?
Those look pretty low and I scrape enough as it is...
