Steering wheel off center
I can't seem to shake my steering problem. The car is a 98 Z and has 275's all around. The steering wheel was off to the left and the car would pull to the right. I had my alignment adjusted to stock specs and it was a little better. The steering wheel is still off center to the left and the car pulls slightly to the right. Would anybody be able to point me to the right direction on how to fix this? Thanks!
It could be normal, depending on how steeply the road you're driving on is crowned. Test it on a flat, straight road and see if it's still there. If so, try switching the front tires from side to side and see if it helped. If it pulls to the opposite side, then you have a tire pull issue and you have to replace them or rotate them to the back of the car. If not, the alignment is still off.
Originally Posted by hpjunky98
check your steering arms on your PS rack. mine are bent and it causes the wheel to be off like you described.
