LCA vs Torque arm
Old Jan 16, 2007 | 03:33 PM
rickssz's Avatar
Default LCA vs Torque arm
If I got either LCA's or a torque arm which one would control spinning (not hop) at launch?
Old Jan 16, 2007 | 04:18 PM
SJM Manufacturing Inc's Avatar
I'd consider new sticker tires for your car before the others.
Old Jan 16, 2007 | 04:31 PM
mthegodfather's Avatar
Stickier tires would be my first mod for hooking then the LCA after of course the subframe connectors.
Old Jan 16, 2007 | 05:09 PM
rickssz's Avatar
using 275/40 /17 nitto 555r @ 17psi Should I try cheater slicks first then try torque arm (or) LCA depending on how the cheaters do?
Old Jan 16, 2007 | 08:52 PM
black01_WS6's Avatar
LCA's with relocation brackets, and a decent tire should set you up ok for now.
Old Jan 16, 2007 | 08:59 PM
2000TransAmWS6's Avatar
tires, then LCAs, then torque arm
Old Jan 16, 2007 | 10:17 PM
Andros's Avatar
If money is an issue I'd try lca reloaction brackets first, torque arm and than better tires.
Old Jan 16, 2007 | 10:19 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You might end up chasing your tail on this one...getting stickier tires might induce some wheel hop, causing you to look at the LCAs and Torque arm. Upgrading one part will quickly introduce the weaknesses of the supporting parts...
Old Jan 17, 2007 | 12:37 AM
matts22's Avatar
That's why I'm going ahead and changing the LCAs and TA before tires. I'll just see how it hooks and act accordingly.
Old Jan 17, 2007 | 11:27 AM
rickssz's Avatar
I guess the Nitto's i'm using are sticky and decent and I thought LCA's were for wheel hop which I have none so Im not sure if the springs are stock or not so I'll check to see if the stock LCA's are horizontal if not I'll get the relo brackets if they are I'll try the torque arm. I'm just looking for a logical order to reduce wheel spin .
