Low trac light?
Old Jan 16, 2007 | 08:34 PM
Blown2000SS's Avatar
Default Low trac light?
when im just driving around slowly, cruising around 10mph, i brake and sometimes the abs/trac light comes on?
seems to be confused, anyone have this problem?
Old Jan 17, 2007 | 05:36 AM
leadfoot4's Avatar
I've had the "low trac" light come on a couple of times over the years, and I don't even have the traction control option....
Old Jan 17, 2007 | 11:34 AM
same here. oh well
Old Jan 17, 2007 | 01:12 PM
Hugger Z's Avatar
That light comes on when your ABS senses a wheel speed differential greater than the threshold where your ABS would activate. Do you guys have staggered wheels where the rolling diameters are slightly different? Or have you changed gears and not updated the computer? Maybe it is just a bad wheel speed sensor or loose connection to the sensor. My winter blazer did that a while back. I had to replace the bearing/sensor assembly. Not sure what it would require on these cars.
Old Jan 17, 2007 | 04:29 PM
im lowered w/ 275s up front. hmmm
Old Jan 18, 2007 | 05:36 AM
leadfoot4's Avatar
I'm lowered, which shouldn't affect anything, but with the same size tires all around.
Old Jan 23, 2007 | 04:37 PM
98silverz28's Avatar
today when i was coming home in my neighborhood (goin about 10-15 mph) my low trac light came on twice. i wasn't spinning, ground was dry, etc. the gas pedal kicks back at you when this happens. if anyone has an idea...post up! i'm sure we'd all like to know what's up
Old Jan 23, 2007 | 05:07 PM
styoung's Avatar
my 2002 dose that but it only dose it when the traction control is on. it says low traction, and the pedel gets hard.
