anyone have this?
Old Jan 19, 2007 | 10:06 AM
L-SS-1's Avatar
Default anyone have this?
does anyone have the panhard rod relocation kit? what does it actually do? how much would it help in cornering?
i'm at work so i cant copy/paste a link right now, but the can be found at thunder racing...
Old Jan 19, 2007 | 11:35 AM
Soltakr's Avatar
The part was first designed so you could run dual exhaust pipes over the axle. However another benefit is a stiffer rear end. You can see a pic of it on BMR's website. I'm ordering one in a few weeks, not because I have dual exhaust but I want to finish off the rear suspension. If you don't have a real good set of tires then all that aftermarket suspension stuff will just over power the grip and cause the car brake out earlier.
Old Jan 19, 2007 | 12:04 PM
trackbird's Avatar
You do not need to buy every part out there to "finish off" the suspension. If you're not going to run duals, you can save the money. All that extra stuff is just good for adding to your signature if you don't actually have a use for it.
Old Jan 19, 2007 | 01:52 PM
Fulton 1's Avatar
Originally Posted by Soltakr
... another benefit is a stiffer rear end. You can see a pic of it on BMR's website. I'm ordering one in a few weeks, not because I have dual exhaust but I want to finish off the rear suspension. If you don't have a real good set of tires then all that aftermarket suspension stuff will just over power the grip and cause the car brake out earlier.
Old Jan 19, 2007 | 02:00 PM
v7guy's Avatar
It helps in making a brace a bit more prone to failure with those extra bends.
FWIW that isn't actually a panhard rod lowering piece, it just creates a dip in the brace for the panhard rod, as mentioned, it was made to create a spot for dual exhaust. There is no handling gain, it will not strengthen the rear end.
There is a set of brackets that lowers the panhard rod. It's been debated if it does any good or not. When doing this mod sway bars, springs and shocks need to be altered as well.
Old Jan 19, 2007 | 02:04 PM
Soltakr's Avatar
Please explain why the SB,springs and shocks will need to be altered. The manufacutre doesn't give any comment about that.
Old Jan 19, 2007 | 02:28 PM
L-SS-1's Avatar
i was thinking this also.
i just thought i would ask since it just mentioned that it was possible to put 3" exhaust over the axle and didnt mention anything about handling,
Old Jan 19, 2007 | 02:42 PM
Fulton 1's Avatar
You're confusing two different things:
1) The BMR brace, which simply replaces the stock PHR brace (aka chassis brace, aka upper PHR, etc) with a tubular part that is joggled to provide more clearance of exhaust.
2) Unbalanced Engineering makes a kit that actually relocates the PHR itself (not the brace) downward. This is what v7guy was referring to with his comment.
Old Jan 19, 2007 | 02:59 PM
Y2K Pewter SS's Avatar
I have it Justin, I will let you check it out soon if you want.
Old Jan 19, 2007 | 05:07 PM
L-SS-1's Avatar
cool
