Handle better than C6, yet still grab rubber?
I basically am looking for a suspension package that will really increase the cornering capability of the car, yet leave some room to grab some tire at the strip. I don't want to be able to cut 1.4 60 fts, yet I would like to be able to cut maybe a 1.7 or 1.7 with a drag radial/slick. Basically I want a happy medium of cornering and traction. I was thinking about slightly lowering the car, maybe 1", which springs would I need? I was also definitely going to get adjustable LCA's, panhard bar, and SFC's. Do you think sway bars would be a good idea? And also, do shocks help with cornering as much, or is it more of a ride quality thing? Sorry but I'm def a noobie when it comes to suspension. If I was to get shocks, I would want adjustable ones so I could corner well when I want, then adjust them for drag racing. Thanks everyone.
Koni SA shocks and Hotchkis Springs would work well. If you need cheaper, then Bilstein Revalves and Hotchkis Springs. That will give you about 1" drop and improve your handling dramatically. Front 34" sawbar will help with cornering and should not affect drag racing.
If you pony up foir the Konis you will have improved ride and cornering. You can save $ and launch ability by keeping stock springs and do the lower perch/hose mod to get a 3/4" drop. And yes, some bigger sway bars will help cornering and have no neg impact on launch. I am very happy w my Strano bars. They are hollow(lighter) and Strano's racing success speaks 4 itself...they r well thaught out.
He also makes some well liked springs that lower and improove cornering...give him a call.
Found this combo on Thunder Racing's website, is this something I should think about, or should I just buy the Billstein shocks and separate springs from somewhere else?
Thunder Racing Shocks
Part # 133-BTS-7501 is what I am referring to.
First, stop looking at information from all those websites since most products are made to sound to do things that they may not really do. Second, you need to tell us what your budget is. In your original post you said "I was to get shocks, I would want adjustable ones so I could corner well when I want, then adjust them for drag racing". Pretty much the only decent shocks that will give you adjustability and good handling characteristics are the Konis (singe -rebound only- or double adjustable ones - rebound and compression- , but double adjustables are overkill for most), but they cost more than the set you are looking at AND don't come with any lowering springs. So if you want adjustables, you need to pay. So you see where this is going financially.
Personally if I were you I would do the following (assuming you have the financial means to do so):
- Koni SAs up front, Koni 3rd gen SAs in the back. Use the lower mounting perch on the front Konis to lower your car ~3/4 inch, and remove the rubber isolator in the back and replace with hose to lower the back ~1/2 inch.
- Keep stock springs
- Get a 35 mm front sway bar (and remove at the drag strip).
- Keep the SFCs, LCAs and PHB for a later time (PHB might be needed if you are using big tires and have rubbing problems).
Good luck.
Good luck.
Hmm, maybe I don't want to spend as much on this as I originally intended. Would the Billstein non-adjustable still be decent at the strip, yet still give a better ride and handling?
Originally Posted by slick1851
If somone gives me a setup with vette like handling etc
I would ditch my drag stuff...
LS1TECH Sponsor
__________________
Sounds like you want a mix of something that you can drive daily, autox if you want to, and take to the dragstrip non hardcore competitively. This is what I would do I was in your position:
1. Koni SA's front and rear
2. Keep stock springs for now
3. Strano front and rear swaybars
and in the future
4. 17x11s all around with BFG KD tires (personal preference
Autox and drag setups are completely opposite suspension setups, though street and autox setups are pretty similar. With a street autox setup you can go to the drag strip and get some pretty decent times, and the ride is much better and more fun on the street. You will probably have a hard time competing with a drag setup on an autox course.
and in the future
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
LS1TECH Sponsor
There was 1.40 seconds difference between us for the event after 100 seconds of time (fastest from each course added up). 1.4 seconds back in a Camaro that's 400 pounds heavier, has taller gearing (and I'm about 100 pounds heavier than Mike is too), I think proves how well a Camaro can be made to handle. This is two equal drivers. I had setup input on both cars, both were on Hoosier tires (315's all around my car, 315 front/335 rear on the Z06).
Ready to dump you drag racing parts?
__________________
