Which would help traction more???
Old Feb 2, 2007 | 11:16 AM
jeremy341a's Avatar
Default Which would help traction more???
Lower Control Arms, LCA reloction brackets or torque arm? This is on a nearly stock 99 Z28 A4 with 3.23's
Car will be used to drive to the track to bracket race and then back home if that makes a difference. I am trying to find something to allow me to dead hook at the track.
Old Feb 2, 2007 | 01:14 PM
Element's Avatar
Tires to start with, but I'd vote for LCAs and relocation brackets after that.
Old Feb 2, 2007 | 01:19 PM
jeremy341a's Avatar
The class I race you have to run a regular street tire.
Old Feb 2, 2007 | 02:17 PM
cakweems's Avatar
If your car is at the stock ride height i would go and do the LCA and relocation brackets first.You can come back and do the TA
Old Feb 2, 2007 | 03:27 PM
68birdls1's Avatar
from what i understand, the torque arm is a better traction provider than the lower control arms and relocation brackets. but i could be wrong.
Old Feb 2, 2007 | 06:03 PM
Hawk108's Avatar
That is the impression that I have gotten also. I have LCA and am having a Torque arm put on right now but i dont think ill be able to help you cuz im also getting 4.11's
Old Feb 2, 2007 | 11:40 PM
DrEvyl's Avatar
teh PuRpL3z
The stock torque will actually handle quite a bit.. stock LCAs are pretty crappy, you can improve them by switching to the 1LE version. The stock LCA bushings are the weak leak in there. Personally, if I was upgrading the suspension, I'd do the LCAs before the torque arm. An aftermarket torque arm with stock LCAs would pretty much suck.
Old Feb 5, 2007 | 03:01 PM
mike#9's Avatar
Lower control arms and relocation brackets will help a hell of a lot more on a near stock car. I would not invest in a T/A right now if I were you. Don't need that until you are leaving hard with some good power.
Old Feb 6, 2007 | 02:39 PM
cowboysfan's Avatar
I'm sure by being "regular tires", they mean D O T tires. which are out there. do a search.
fuerzaws6
