sway??????????
Sam Strano makes a nice matched 35mm/22mm hollow set of sway bars for handling, and are less expensive than the Hotckhis bars. The Hotchkis are larger on both ends at 36.5mm/24mm hollow and most agree that the 24mm on the rear is usually too much bar. Hollow bars are nice to save weight, but you could substitute a slightly smaller diameter 21mm solid bar on the rear if you had access to one. Suspension Tecnhiques does make a 35mm solid front bar, but the thing is very heavy and I'd opt for hollow just to save weight.
For pure drag racing, you would want a large rear bar and probably disconnect the front bar when you're at the track. It all depends on what you're trying to do, but for a "handling car", Sam's setup is pretty nice.
Many folks have my bars, and mine are the only ones that are actually used to compete and win handling events. I specified the sizing myself, commissioned the bars to be made, speced the endlink strength, and have used them to win two of my National Championships.
And I thought you said you weren't a good salesperson.
I have Sam's 35mm bar waiting to go in this weekend. Black powdercoated, all new poly bushings and hardware included. Very nice piece.
I love swaybars best mod for an fbody IMHO.
