LCA relocation bracket trouble :(
will not squat anymore.
you push on the hatch and the car is rock solid.
drives down the road like my 3/4 ton truck. high speeds seem very unsafe to me now. car roars like im riding on a flat tire. i really cant explain it.
car has always ridden like a cadillac, even with skinnys and et streets.
no other parts were changed.
loosed the back bolt on the lca, hooked it to the bracket and welded it in place.
im puzzled. i was hoping for every bit of ET i could get out of my setup, now im ready to burn it.
the brackets made your control arms drag oriented, so youre gonna have that added stiffness.
i doubled checked pinion angle just to be sure, and its still -2. checked the spohn instructions and talked to 2 different drag racing buddies(matt....brandon) and its set right, AFAIK.
What is the torq spec's on them?The Best V8 Stories One Small Block at Time
im going to undo the sway bar, shocks and lca's tomorrow, and just bolt everything back up and go from there.
maybe ill notice something.
prolly wasnt holding my tounge right the 1st time.
the bar is up in the front, and angled down on the rearend side.
going out there shortly to see if i can figure something out.
lca fell out of the bracket once i took the bolt out, so they werent over torqued or in a bind at all.
problem has been fixed!
made my own shock relocation brackets for the rear, and the bolts i used were just a shade too long. my anti roll bar was sitting on the bolt, not allowing for any flex.
stupid me, but i didnt notice it the 1st time.
when the car was in the air for inspection, the sway bar is no where near it, but once loaded, it was setting on the end of the bolt.
DOH!
thanks for all the help.
depending on the size(or brand) of your sway bar, make sure you use a bolt thats near perfect size. for the shock brackets.
Do you have a picture? Do you mean you changed where the shock attaches at the lower end? Why? Not to be a smarty pants just trying to learn and understand.
i just wanted to save a buck from buying them. of course if i would have used his brackets, id have the correct length bolt the 1st time.
they are on thunder racings site to get you an idea. lots of people converting over to them.
all in all id say the LCA relocation brackets work.
havent been to the track, but with a gear change, i ran into some traction issues.
it didnt cure it, but the car doesnt blow the tires off at such a low roll anymore. so they are putting a lil more force on the tires.
