Question for UMI about relocation brackets
and is there anything that would prevent me from using the bolt-ins on my 10-bolt now, then chopping off the extra "tab" and welding them onto a 12-bolt at a later date?
I will be glad to help.
The relocation brackets for the 12-Bolt and 9" are designed for the Moser 12-Bolt and 9" only. The Moser control arm mounts use thicker steel and they make them wider then factory. This means we now need to make our relocation brackets wider to fit over Moser's control arm mounts. If you purchase the bolt on brackets they most likely will not fit correctly on the Moser rear end. However if you purchase a Strange rear end they will go right on.
If I can help anymore please ask. Thanks
Ryan
if/when i do order, i will definitely be buying from you guys
Thank you!
Ryan
You ordered a weld in set two weeks ago from us and haven't them yet? There is something wrong then, order misplaced or anything, or ordered with other items maybe. Please PM me a name and I can look into.
Thanks,
Ryan
Thank you,
Ryan
I know Ryan is installing his own system for this to try and speed up delivery times when it's very busy. As much of his stuff as I sell, he'd getting orders from other vendors too.
Again thanks for responding and getting involved.
