ls1 brake swap help
ls1 brake swap help
I have all the stuff I need for an ls1 brake swap on my lt1 camaro....except for the steering knuckles. I do need these, right? I am having a hard time finding some, and I dont want to pay 170 for each new.......
you should be able to find a set of spindles on here or ebay for $75-100. If you decide to keep your LT1 spindles then you can go with UMI C5 brakes adapters and C5 abutment brackets (caliper brackets) and your LS1 calipers. Doing so will bring you up to 13 front brakes and may require a 17 or larger wheel.
The steering knuckle is the main part. Can you run the larger rotors on your car?
If so, here are the steps of doing the LT1 to C5 swap. You can keep you LT1 knuckles, but you will have to do some cutting on them. Maybe the difference in price to get bigger 13" rotors is worth it for you.
http://community.webshots.com/album/108708798nQHLxR/0
I have stock wheels right, so I believe the ls1 size rotors are as big as I can go.
I already have everything for the swap except for the knuckles. Can I cut the knuckles for the ls1 rotors aswell? I looked on ebay and can only find complete sets with rotors etc, or single lh knuckles.
You might try some of the parts guys here on this site. Check the for sale and needed sections. There are quite a few guys who buy these cars and part them out. Maybe they will sell just the knuckles.
Because they are completely different. The LT1 has molded brake caliper holders while the LS1 has just 2 bolt holes on the knuckle. The caliper bolts to a PAB (pad abutment bracket) and then the PAB bolts to the knuckle. If you don't know this I'm not sure your ready to do the swap.
Do you already have the new calipers, PABs, rotors, pads and all the small parts?
I was going off of the directions on fbody.org, and I've got a couple different tourque wrenches......I was hoping to get this done during spring break(next week), but I really need those knuckles
That's a pretty good guide, but I would go and get a Chiltons manual from the local autoparts. It will show torque specs.
The 2 big bolts from the PAB to the spindle need to have loctite and be torqued to 75lbs. This is important.
The guide pin bolts from the PAB to the caliper are smaller and only need 23lbs plus loctite.
There is also some guide pin lube that is silicone and high temp at the local auto parts store. I would get some of that as well.
They don't check those parts. It's hard to say the condition of them. You'll know once the knuckle is off. Just wiggle them back and forth. They should be pretty stiff and hard to move. If they flop around easily or with a tiny amount of hand presure then replace them. It's better to do it during the brake swap than to tear the suspension down again later.
