Anyone Interested In 14" Brake Kit?
#41
Under hard use the Z06 padlets tad to wear unevenly which means you have to check them more often and replace any pads wore down excessively. The pad material is also thinner so they don't last as long.
Lastly (on the Z06), the heat and pressure of hard use tends to bend the pad retainer bolts making them very difficult to remove. If the dealership can't get the bolts out they will just replace the whole caliper under warranty. We won't get a warranty, so we'll have to pay out of pocket.
The C6 Z06 rotors seem to be fine.
#43
wow this has really caught my attention. Jason with all that info you just posted thats in regards to the C6 brakes both calipers and rotors, right? So by going with the C6 rotors which dont seem to be faulty by themselves and going with the Caddy calipers which are proven performers you would be getting a top performing brake setup. I like where this is going.
#49
I haven't heard of any problems from racers using the C6 Z06 rotor. The only thing slightly funky about them is that the cooling vanes run different directions because the same rotor fits on both sides. Some people have suggested that one side might get overheated, but that doesn't seem to be the case.
The only other thing is that the cross drilling faces clockwise on one side of the car, and counterclockwise on the other side. That might be a problem if you're extremely ****.
#50
$700 is still chump change compared to most big brake kits. I think the Stoptech kit is $2000. The Porsche big red setup might be a little bit less, but it's still up there.
#51
ya thats what i mean C6 Z06. Im subscribed to this thread and the other ongoing one about this. I can see the C6 Z06 rotors and CTS-V calipers on my car in the near future. I just need someone to test them out first and see if 18.8.5 rims will work with them
#55
#60
Nope, clearance will be real close on yours. It may clear or you'll need a thin spacer. All the C5/C6 rotors mount the rotor further out than the F-bodies so you lose some room right there, then the thickness of the caliper is what really takes up space. The combination of the 2 takes away right around 1.2" (1 1/4")
