Installing Breaks
Old Mar 21, 2007 | 09:44 PM
Intense's Avatar
Default Installing Breaks
Is it as easy i tihnk it is... I am going to put on Slotted Rotorworks Rotors, and Hawk pads. I want to change the fluid also. Will it be as easy i think or am i in for a long hall?
What little things should i look out/ worry for
Old Mar 21, 2007 | 09:58 PM
cookba's Avatar
its really easy. get a buddy to help and you'll be done in no time. ide recommend the solo bleeders while your down there. and use gloves while working on the rotors and clean EVERYTHING before your done and drive away. you may have to bleed the brakes a few times. i bled mine 3 times. once after break in period, once after some hard ABS stops, then once just for the hell of it
Old Mar 21, 2007 | 10:09 PM
Intense's Avatar
Ok... THanks alot.. if anyone else has opinions or suggestion please let me know
Old Mar 21, 2007 | 10:39 PM
VIP1's Avatar
Copy & Paste Moderator
http://www.installuniversity.com/ins...ds_mwarren.htm
Old Mar 21, 2007 | 11:43 PM
RoadHazard's Avatar
It's not difficult. When I did my rotors, the hardest part was removing the caliper bolts. Everything else is straightforward. And remember to break in the pads properly.
Old Mar 22, 2007 | 10:05 PM
Intense's Avatar
Does it matter the brand of break fluid? As long as it dot 3 correct?
Old Mar 23, 2007 | 09:52 AM
VIP1's Avatar
Here is some more info about brake fluid:
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
You can upgrade to a DOT4 like ATE Super blue.
Old Mar 23, 2007 | 10:04 AM
z28bryan's Avatar
Its very easy. Instructions are on installuniversity.com
BTW, you spelled retarded wrong in your sig.... you might want to fix that if you want your Honda statement to sound more effective
Old Mar 23, 2007 | 11:06 AM
koolaid_kid's Avatar
That's O.K., he also mispelled "you're".
Old Mar 24, 2007 | 06:57 PM
VIP1's Avatar
And breaks should be brakes.
Old Mar 24, 2007 | 11:22 PM
mitchntx's Avatar
Class dismissed
Old Mar 25, 2007 | 12:07 AM
DONAIMIAN's Avatar
I wouldnt waste your money on the solo bleeders, after a while the spring dies and they dont work as well anymore.
Old Mar 25, 2007 | 11:34 PM
VIP1's Avatar
Originally Posted by mitchntx
Class dismissed
But little joey keeps putting his hand up.
(BTW, I don't know the names of anyone on this thread so hopefully I didn't just use someone's name in that joke.)
