Installed Earls SS lines but have question.
These lines noticeably improved my braking and pedal feel but I have a question about the kit. It came with 5 lines, four labeled for each corner of the vehicle, but a 5th labeled "rear center". I know the kits are universal for other vehicles but we looked all over my car for a place to install this. It had a regular fitting for a brake line bracket, but the banjo had inputs for two lines. Anybody know where this goes, or is it just "extra".
LS1TECH Sponsor
It's there.... goes from the body to the axle. Has to be a flex line, or something would break when you drove the car. Look harder.
And FWIW, TCS/ASR cars have 6 lines in total....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Yeah, if you are 3 channel ABS (non traction control) then look on top of the differential. you can follow the hard lines from each soft line that you replaced in the rear. They will meet on top of the diff. this is where the 5th line connects to the hard line that runs back up to the engine compartment.
Originally Posted by mitchntx
TCS and ABS has nothing to do with the 5th line.
The fifth line attaches to a Tee block on the top center of the diff and the hard line that runs along the fdriver's side frame rail to the ABS unit.
My TCS car had dual hoses to the rear (one at each wheel and 2 on the axle, 6 total) because the ABS has seperate circuits for the rear brakes to allow the TCS system to grab one wheel at a time. You can't do that through a T block and a single hose. An ABS only car has 5 lines and uses the hose with a T block, the TCS car uses dual lines without T blocks, one per caliper on the rear axle.
All non-TCS SS brake line kits SHOULD come with 5 lines ... 1 for each corner (4) and connecting the rear diff (1) ... 4 plus 1 equals 5
If a car has TCS, a 6th line should be involved, but Mr. blo clearly states he has a 5 line kit.
Non TCS cars have a electrical connection in the top of the diff which feeds off a reluctor ring sandwiched between the ring gear and carrier inside the diff. The signal is fed to the ABS module under the hood.
That's where we looked and that's what I figured. I followed the rear lines to the center of the diff. and didn't see it. Maybe just need to look harder and get the car on a lift to do that one, thanks guys!
BTW, it does have TCS.
Copy & Paste Moderator
