severe vibration!
severe vibration!
well just the other day i finished installing new brake pads on my 98 and made sure everything was lokking good! when i took her out for the break-in runs i noticed a bad vibration through the steering wheel and shifter. the vibration happened when i went around steady long right turns and also in a straight line under hard accel right around 40+ mph. anyone have any ideas about what might be wrong? thanks in advance!
If it's happening during turning, it sounds like something isn't right with the install. Double check to make sure everything is tight and in place.
It could be a shimming issue on the pads too.
it does not happen during brakeing only under accel. and i ran around and made sure the lugs were tight...once it warms up a bit im going to remove the rotors again and get them returned
well, i inspevted the wheels and sure as day the tie rod end on the driver side is shot to hell... so im getting a new one and hopefully that fixes it! **cross fingers**
