Q on installing Adj. TA
OK, new Q... When looking from the pass side of the car my driveshaft angle that I recorded is 2 to the right of zero, and my rearend # is Zero, so does this mean I have -2 degs?
I'm in the middle of installing my UMI tunnel mount Adj. TA. The tunnel mount brakets that are used to connect to the TA have 2 sets of holes to mount the TA to. Which ones are recommend to be used the upper hole or the lower hole? I'm sure this has probably been asked a million times, and search isn't working for me.
Any other suggestions are welcome!
Thanks
Thanks
I installed the UMI tunnel brace mount adj. TA. But i don't recall two sets of holes. The brace has one bushing in it, and the TA has one bushing. The two plates go on either side of those bushings.
http://www.umiperformance.com/images/2203d.jpg
My bracket is longer than that one and has another set about a 1/2" above those. I just used the lower ones anyways, looked more like the pic.
Also, when looking from the pass side of the car my driveshaft angle that I recorded is 2 to the right of zero, and my rearend # is Zero, so does this mean I have -2 degs?
Well I sent UMI an email and explain everything in detail, and there reply was to give them a call! Well, my work hours don't allow me to call them during there hours of bussiness. So any help here would be greatly appreciated.
Thanks
Thanks
