Koni SA Recommended Settings?
#41
Originally Posted by Jeff Smith
Is this pix>>Custom Shocks? For Camaro front shocks?
I like this one
. I want to get more information of this pix..
Good news for Road Racing?
Is this Koni shocks? what Shock part nu.?
I like this one
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
![](http://img.photobucket.com/albums/v335/JasonWW/Misc%203/FrontLGCoilOvers1.jpg)
$2300 a set. More info below:
http://www.lgmotorsports.com/catalog...7c10dcee64622b
There's not many pics of his setup out there, but I have a few installed shots.
Also, I don't run a front isolator as I don't think it's needed. Who knows, maybe it would help the ride quality. I'm assuming you mean install it between the spring and the hat?
#42
So back to what another member said earlier, Koni's come set on full soft from the factory?? Im having New Era Performance(SPONSOR) install my shocks(4/4 Koni's) and Strano Springs on thursday and I might as well have them adjust them to what settings I think Ill need to start out with, then I can adjust later. From what I've read, 4 1/2 sweeps from full on front, and full soft on rear seem to be popular..... any feedback?
#43
TTT..WOW expensive$$$. Nice design..
Have anyone build homemade like this one? I think about building one ..![Try Search](https://ls1tech.com/forums/images/smilies/trysearch.gif)
[QUOTE=JasonWW]It's not new, it's LG's racing coilover set. It also has real coilovers in the rear shock location.
#44
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I actually do run my rears a bit firmer. For some reason with my rears on full soft the ride is good, but I loose grip accelerating out of turns. About one full turn firmer helps that situation. I guess the softer setting allows the rear to lean a bit faster and the grip goes down. I'm not sure, but that's the way it is with my car.
#45
