Noise in rear, suspension?
When i go over bumps or pull into my driveway i hear a noise coming from my rear suspension. It sounds like the noise of a wood floor creeking. Is that my shocks going bad or something else. It rides nice and no other noises are present. The only suspension mods to date are sfc's and stb, and the car has close to 70k. Thanks guys.
Originally Posted by ShevrolayZ28
Mine was doing that and it turned out to be dry rear sway bar end link bushings. I sprayed some jiz on there and it the noise went away.
Its been raining all day so i haven't gone under the car and spayed the sway bar bushings, lca bushings, etc.. When i do, i will let you guys know if it solved the noise.
Rattle from pass. wheelwell: Have you checked your spare tire/jack to see if they are loose?
