motor mounts
Old May 5, 2007 | 01:22 PM
blackbyrd's Avatar
Default motor mounts
does anyone know where to get the metal bracket surrounding the rubur peice of the mount. i sold mine thinking what i was getting came with it and now i dont have it.
Old May 5, 2007 | 02:44 PM
InjectedSS's Avatar
Here you go. Better get bidding
http://cgi.ebay.com/ebaymotors/1995-...spagenameZWDVW
Old May 5, 2007 | 03:01 PM
blackbyrd's Avatar
will those work on an ls1??
Old May 5, 2007 | 06:41 PM
TheSilverOne's Avatar
i dont think so
Old May 5, 2007 | 09:44 PM
InjectedSS's Avatar
My bad dude for some reason I thought you had an LT1 because you said you sold yours and I assumed that you bought a tubular k-member or something and I know that the LT1 k-members come with a mount for only the RH side.
In any case NO those mounts will not work unless you have an LT1 in your car Below are some other mounts I found that should be what your looking for
Actual engine mount
http://cgi.ebay.com/ebaymotors/98-02...QQcmdZViewItem
RH Mount
LH Mount
Old May 6, 2007 | 08:46 AM
blackbyrd's Avatar
yeah i need whats in the fist listing to bad its only 1 of them
Old May 6, 2007 | 12:27 PM
InjectedSS's Avatar
You might just want to email that seller man, he has quite a bit of stuff. In another auction he has TWO listed be he is selling the mounts with them as well.
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
So I bet if you check with him he would probably be willing to work something out.
Old May 6, 2007 | 02:29 PM
blackbyrd's Avatar
scratch that is there a company that sells aftermarket kit all together for the poly mount anbd the bracket cause i just found out i got the wrong part
Old May 7, 2007 | 09:12 AM
blackbyrd's Avatar
no one has done this or does anyone have the part number so i know for sure i got the right part??
Old May 7, 2007 | 10:39 PM
blackbyrd's Avatar
no one is running aftermarket motor mounts??
Old May 7, 2007 | 11:40 PM
soulless's Avatar
Here ya go link .
Old May 8, 2007 | 06:52 AM
blackbyrd's Avatar
will that work with a umi k member
Old May 8, 2007 | 04:26 PM
soulless's Avatar
UMI's website says it has intergrated motor mounts, I would call them to see though. Here's the link.
Old May 8, 2007 | 06:25 PM
blackbyrd's Avatar
im pretty sure it is just the stand for the mount, it is not a motor mount itself. In other words, no bushing.
