Control Arm Question.
Old May 6, 2007 | 01:03 AM
boostedbuford's Avatar
Default Control Arm Question.
As you can see I'm running D/R's w/ no suspension mods at all, I can pick up a set of control arms for pretty cheap. Will this help my nasty wheel hop?
Any other suggestions for minimal suspension mods that will greatly reduce wheel hop w/o breaking the bank??
Old May 6, 2007 | 01:23 AM
Shock Hawk's Avatar
If you have lower control arms, then you are probably missing the relocation brackets. If you don't have lower control arms, buy some adjustable ones and relocation brackets. A friend of mine killed his 10-bolt because of wheel hop from LCAs without relocation brackets.
Old May 6, 2007 | 09:41 AM
Old Geezer's Avatar
Curing wheel hop involves the use of good shocks, proper air pressure, good bushings. Relocating the control arms won't do it.
Old May 6, 2007 | 04:15 PM
Out1aw's Avatar
I beg to differ on that. Relocation brackets cure the problem of instant center on f-bodys. The IC is the imaginary point where the planes of the torque arm and lca's meet. it should be somewhere around the firewall area, but as it's set up from the factory, it's either 100's of feet infront of the car, or not there at all if the car has saggy springs. this thread on www.thirdgen.org really explains it well with pictures and everything: http://www.thirdgen.org/techboard/su...arm-angle.html
if this angle issue is not corrected, you will experience wheelhop when big power is applied with a sticky tire.
Old May 6, 2007 | 08:10 PM
Old Geezer's Avatar
Question Ok..
Is that so?? I guess my GN forgot to hop, when I applied enuf power to run 9's, at over 141...Stock location arms, good bushings in my control arms,[upper and lower] proper pinion angle, good shocks, HR antiroll bar. [HALS-12 setting design.]
Old May 7, 2007 | 02:40 AM
Shock Hawk's Avatar
The wheels probably don't spin with sticky tires running 9's. My friend was spinning the tires when his wheel hop from missing relocation brackets tore teeth off his ring gear.
Old May 7, 2007 | 04:35 AM
revtime's Avatar
Keep in mind a Buick GN has a completely different suspension setup than an Fbody.
LCAs and relo brackets completely cured my wheel hop problems.
Old May 7, 2007 | 02:14 PM
Out1aw's Avatar
Exactly. This thread is about an F-body's constant problem of wheel hop and lack of attaining instant-center... not a turbo Buick...
