Warped Rotors
I haven't torn into it yet, but is the hub assembly like it is on most other front ends - cap, cotterpin, hub nut, inner and outer bearings?
What is the torque setting / procedure for reinstalling the hub nut? (lb ft. to torque, and how much to back off afterwards)
I'll repack bearings and replace grease seals while I'm in there.
You only need to replace the rotor.
Here is a write-up:
http://www.installuniversity.com/ins...ds_mwarren.htm
(I'd suggest doing one side at a time instead of putting the entire car on jack stands at once though.)
VIP1, thanks for the awesome writeup.
In other words... all stock replacements (as opposed to larger rotor kits or rotors for other vehicles ex: Corvette rotors require a bracket to move the caliper outward for them to fit on a f-body, the installation may require other components as well).
Check out this FAQ:
https://ls1tech.com/forums/showpost....91&postcount=5
