Konis installed. Couple problems. Gurus & Sam please look.
Old 05-28-2007, 05:19 AM
GTObsessor's Avatar
Default Konis installed. Couple problems. Gurus & Sam please look.
Alright I just installed my Konis from Sam about 4 days ago (and have about 100 miles on them now).
1) First off, the car likes to wander on uneven roads A LOT more now. Settings are 4 sweeps from full hard in front, 1 turn from full soft in back and set on the lower perch in front.
2) The front fenders now rub into the tires on hard corners (~2mm patch, found rubber in between the fenders, never happened before).
3) Also, the car seems to push HARD like it's spring loading then jumping back at me in jerking turns @ high speeds ONLY (around 100ish). This is amplified greatly over bumps and again, uneven surfaces.
It seems like the back is coiling up on me and pushing back too hard, but this is just the feeling i'm getting. I'm getting an alignment done ASAP but thinking about adding Strano's bar up front (still too much body roll). Will this screw with the alignment at all or will installing a sway bar have no affect on alignment in the future? Thank you!!!
Old 05-28-2007, 05:23 AM
subtlez28's Avatar
Did u change anything else?
Springs?
Lower it w Koni lower perch?
I'm thinking alignment problem....u did have it aligned, right?
Old 05-28-2007, 07:18 AM
coolformula's Avatar
Kind, coniditon,air pressure of tires?
Old 05-28-2007, 08:05 AM
Pontiacerator
RevGTO's Avatar
Assumng that the front shock assemblies are properly installed and tightened, your alignment is way off. When you get that done, your front end problems should go away. Try your rear shocks on full soft. Sway bar won't affect alignment.
Old 05-28-2007, 11:02 AM
Copy & Paste Moderator
VIP1's Avatar
You lowered the front by using the lower spring perch which changed the alignment. You need to get the car re-aligned. Get an alignment and see if there are still any issues.
https://ls1tech.com/forums/showpost....38&postcount=3
Old 05-28-2007, 02:14 PM
GTObsessor's Avatar
Springs?
They're Koni SA's all around. Front tire pressure is at 30psi on 275 Perelli PZero Nero M+S with about 2/5ths tread left. Reinstalled stock WS6 springs. Only thing I changed was putting them on the lower perch. Nothing else was changed and everything's nice and tight in there. I'm getting an alignment done tomorrow. Everyone's closed for the holiday weekend. Thanks for the input guys
Old 05-28-2007, 07:39 PM
SpdFrk1990's Avatar
30psi seems a little low on the front tires.
Old 05-28-2007, 09:19 PM
GTObsessor's Avatar
If you look inside the door, the sticker calls for 30 PSI on 275/35/17 tires. Still wearing very well for 32k miles on them
Old 05-29-2007, 02:05 AM
SIK02SS's Avatar
ryan, where are you taking 100mph turns?
and get the alignment done, and see from there..did you do the hose mod too?
Old 05-29-2007, 05:43 AM
GTObsessor's Avatar
I'm just talking about freeway curves on a run I had a couple days ago. I got skurred. No more of that untill after I get an alignment done... I mean... I would never do tripple digits on the road, what are you talking about??? I should get an alignment done at that place Keefus mentioned tomorrow.
No hose mod. Didn't wanna go through the trouble of dropping the rear end since the duals are under there. I actually really like how the car sits now. I don't mind a little rake at all
Old 05-29-2007, 10:54 AM
LS1TECH Sponsor
Sam Strano's Avatar
First, get your car aligned. Second, you need to play with the shock settings and see what you like best. 1 turn up in the rear is much more than I tend to run....
__________________
Old 05-30-2007, 10:17 AM
GTObsessor's Avatar
Dam. And the third gen rears have to be taken back out to adjust, right? No biggy.
Old 05-30-2007, 10:38 AM
DuronClocker's Avatar
I think you just need to pull the bottom nut off, back the shock out and spin it one way or the other, and then just re-install that shock end and nut.
That's what I'd gathered before I bought them. I went with the 4/4 setup, so I don't know for sure though.
Old 05-30-2007, 01:26 PM
GTObsessor's Avatar
Can anyone confirm or deny? I should be able to get to the 'button' to adjust it from there.
Old 05-31-2007, 09:42 AM
rd_ls1_z's Avatar
Did your rear shocks come with an adjuster ****? If so, all you need to do is pull up the rear carpet to access the upper shock mount, place the **** on the top, and turn in the "-" direction for softer. At least that's the case with my Koni's.
Old 05-31-2007, 09:47 AM
No, that's the 4th gen style that we have. He's got the 3rd gen style that requires at least partial removal to adjust them.
Old 05-31-2007, 12:55 PM
rd_ls1_z's Avatar
Oh, my fault....Bummer on having to do a partial removal.....
Old 05-31-2007, 01:26 PM
SIK02SS's Avatar
u get the alignment Ryan?
are you still running the 555Rs in the back?
Old 05-31-2007, 01:56 PM
LS1TECH Sponsor
Sam Strano's Avatar
Spoke to Ryan yesterday, the little pie-shaped shim was left out of one of the front shock mounts, which isn't helping anything.
__________________
Old 05-31-2007, 03:10 PM
BAD LUK's Avatar
pie-shaped shim??
I installed the SA's all around (along with Sam's front and rear bars) about two years ago and can't seem to recall this shim. Where is it located exactly?
