what would help me hook
I just installed my 228R cam and a 75 shot and i cant hook for nothing at all. What suspention upgrades do i really need to make to hook, i already got WS6 Wheels with Kuhmo Escta MX's in the works so hopefully that will help! i would just like to be able to hook when i drop it at 2.5k on my 3000stall and GO with as little spin as possible!
The first 2 things I would do is get some trailing arm relocation brackets and some drag radials. Nittos and MT/ET Street seem to be the most popular. From what Ive read the Nittos hook a little better on the street than the MT's, but the MT's hook alot better on the track. Also the Nittos have about twice the tread life.
thanks guys, i think im going to go with a good set of tourqe arms, and LCA's with that bracket and see what happens when i get those wider, stickier tires on it. thanks again.
You will notice a hell of a difference!
p.s you only need 1 torque arm. It's the triangle shaped piece that goes from the rear end to the tranny next to the driveshaft. You will need 2 LCA's and 2 re-location brackets though. They are sold as a set each though, so really you need a pair of LCA's and a pair of brackets
LCA's and Relocation brackets, i just did them i noticed a whole world of difference and my tires are BALD so im sure ill notice even more when i get my new tires
I went with UMI brand they are pretty good as far as ive heard and felt
Originally Posted by SSmoked!
Do you still have the stock 10-bolt? because if you do with that torque arm you can kiss it good buy!!!
Originally Posted by 97SUPERFORMY
really? i never drag race, just roll from 25-35mph, is there anything i can do to make the 10-bolt ready so i can put the tourqe arm on, i havent got a tune yet, im taking it to a bigger city soon, but im sure when i start useing my full shot of nitrous ill be at about 450hp, so im thinking one shredded *** 10-bolt if i can put it ALL on the ground.
sticky tires + 450 hp + torque arm + stock 10bolt = tow truck
